Manual or Automatic Device Creation
Sun Apr 26, 2020 10:00 am
neilk offline
Hi all,
In one of the plugins I am working on it only makes sense for a single device instance to exist, and it can be configured using the plugin configuration. I am tempted (to increase my knowledge) to have the plugin automatically generate the device, but before I do that what would you describe as best practice , letting the user create a device with zero config but with a name and folder location of their choice, or automate the creation ? The device will show the current electricity rate for the property postcode.
Neil
Sun Apr 26, 2020 11:03 am
Re: Manual or Automatic Device Creation
I always use plugin creation when possible for devices and variables.
But most of my devices have many parameters and it is easier to just create them properly instead of asking the user to set everything right.
The issue though is that the user still can duplicate the device or delete it manually.
That would be a nice feature to have : devices that can not be changed / created/ duplicated by the user, or only when the plugin is not running.
Sun Apr 26, 2020 11:20 am
In your case, I would have the user create the device and provide the post code at device creation time. There's no reason to limit the user to only one property in a single post codes, you should allow for multiple devices.
Sun Apr 26, 2020 1:17 pm
neilk offline
Thanks both, and Joe - I will implement as you suggest, you stop me going down a route of adding more complexity for less flexibility.
Neil
Mon Apr 27, 2020 9:04 am
As a general rule, you shouldn't automatically create devices. An exception is when a user adds a device that creates multiple linked devices (like a multisensor or the Airfoil instance that creates the linked speaker devices). Having the user in control of when and where devices are created has always been how Indigo works and we believe it should continue to be the standard approach. If discovery is possible, then a great user experience is to show the user a list of potential devices in the device create dialog so they just pick from a list of available devices (i.e. the Z-Wave plugin).
