add dev.pluginProps parameter for limits white temp color
Sun Mar 08, 2020 2:35 pm
It would be nice to have a setting in device.xml or pluginProps for "SupportsWhiteTemperature" enabled devices to set the upper and lower limit for temperature value of the color
In my recent experience the LED lamps have a varying range from lower 2700 ..3200 to .. upper 6000 .. 7000K .
The current limits in indigo are 1200 K- 9000k ( from tries to slide left/right)
It poses some challenges to correct that after the user has entered a value slide to far right > than the physical limit of the bulb and the bulb does not handle it. One can overwrite the entered value, but that makes the slider jump around after the user set the parameter.
So a field
<Field id="whiteColorTemperatureLowerLimt"  type="textfield" defaultValue ="1200"  ><Label></Label></Field>
that indigo uses to limit the data entry / slider range would be great (same for upper limit), Or in other words a standard dev. whiteColorTemperatureLowerLimt property that indigo uses for that limit
Sun Mar 15, 2020 3:41 pm
Re: add dev.pluginProps parameter for limits white temp colo
Hi Karl,
Not sure if you saw it, but the Relay and Dimmer example in the SDK shows there is a minimum and maximum for white temperature (last two lines):
-> SupportsWhite: True or False (requires SupportsColor to be True)
-> SupportsTwoWhiteLevels: True or False (requires SupportsWhite to be True)
-> SupportsTwoWhiteLevelsSimultaneously: True or False (requires SupportsTwoWhiteLevels to be True)
-> SupportsWhiteTemperature: True or False (requires SupportsWhite to be True)
-> SupportsRGBandWhiteSimultaneously: True or False (requires SupportsRGB and SupportsWhite to be True)
-> WhiteTemperatureMin: Optional integer value for minimum white color temperature
-> WhiteTemperatureMax: Optional integer value for maximum white color temperature
Sun Mar 15, 2020 4:01 pm
i need better reading glasses
Sun Jun 14, 2020 1:20 pm
matt (support) wrote:
Hi Karl,
Matt - where is the version of the SDK that has those last two fields in it? The Wiki has a link to http://www.indigodomo.com/Indigo7SDK, but that downloads the a file from 2016 that does not have those fields in it.
Sun Jun 14, 2020 3:05 pm
Hi Joe – Sorry, looks like that was a stale link. I've uploaded the latest you can grab here.
Sun Jun 14, 2020 3:27 pm
