RGB dimmer devices access to build in states
Fri Feb 28, 2020 11:56 pm
2 issues:
1.====
for RGB dimmer devices brightness seems to either 0 or 100, nothing in-between.
in the sdk is also no example on how to set this,
how is is calculated. just 0 or 100 for on/off?
2.===
the building devise stated eg redLevel can be set withe dev.updateStates ...()
but i am not able to read them:
tried
 if "redState in dev.states .. is False
xx = dev.states["redLevel"] throws error
dev.redLevel shows None
doing indigo.log( unicode(dev) ) shows
batteryLevel : None
blueLevel : None
brightness : 0
redLevel : None
although they do show a value in the detailed device pane
And finally a python question:
how do I access dev.ppp
with ppp a variable = "redLevel" / "greenLevel" / "address"... (dev.redLevel works but shows None)
shows error: 'DimmerDevice' object has no attribute 'ppp'
Sat Feb 29, 2020 12:39 am
Re: rg dimmer devices access to build in states
it seems the devices was not properly initialized -- the properties supportXXX was not set .
BUT still the 2 questions remain:
== for RGB dimmer devices brightness seems to either 0 or 100, nothing in-between.
==And finally a python question:
Sat Feb 29, 2020 8:55 am
as for the python question:
This works,
xxx="redLevel"
exec("aa = dev."+xxx)
indigo.server.log("returned: "+ aa)
but there must be a pythonic way
Sat Feb 29, 2020 9:42 am
xxx="redLevel"
value = getattr(dev, xxx)
Sat Feb 29, 2020 2:46 pm
Re: rgb dimmer devices access to build in states
ok thanks,
and the brightness value =0 or 100, nothing in-between?
Sun Mar 01, 2020 11:22 am
Some more questions on brightnessLevel (not brightness)
The attached:
Screen Shot 2020-03-01 at 11.04.32.png (15.1 KiB) Viewed 1906 times
shows a dimer device w prop SupportsOnState True, SupportsWhite True
I am updating state: "brightnessLevel", the number in the slider is correct, the position of the slider is NOT as well as the Brightness number on the right
setting state "onState" to False sets brightness to 0 as well as the slider - and the other way around
I here a setting I am not aware of, or how should:
"SupportsColor"
"SupportsRGB"
"SupportsWhite"
"SupportsWhiteTemperature",
"SupportsRGBandWhiteSimultaneously"
"SupportsTwoWhiteLevels",
"SupportsTwoWhiteLevelsSimultaneously"
"SupportsOnState"
"SupportsSensorValue"
"SupportsStatusRequest"
"AllowOnStateChange"
be set to for
1. a simple dimmer
2. a dimmer with white color / temp
3. a dimer w RGB only
4. dimmer w RGB & W & temp
Sun Mar 01, 2020 12:25 pm
The RGB Color devices support overall brightness as well as individual R, G, B (and up to 2 white channels) levels to specify the color. The Example Device - Relay and Dimmer plugin in the SDK has the best documentation on all of the properties and their dependencies:
SupportsColor:                                  True or False
-> SupportsRGB:                                 True or False (requires SupportsColor to be True)
-> SupportsWhite:                               True or False (requires SupportsColor to be True)
      -> SupportsTwoWhiteLevels:                True or False (requires SupportsWhite to be True)
      -> SupportsTwoWhiteLevelsSimultaneously:  True or False (requires SupportsTwoWhiteLevels to be True)
      -> SupportsWhiteTemperature:              True or False (requires SupportsWhite to be True)
      -> SupportsRGBandWhiteSimultaneously:     True or False (requires SupportsRGB and SupportsWhite to be True)
So note SupporsColor needs to be set to True for any of the other properties to be used.
Sun Mar 01, 2020 1:10 pm
Re: RGB dimmer devices access to build in states
I red all of that, that is clear..
after some more testing it seems to be:
when "onOffState" is used brightness only follow sTHAT state, not brightnessLevel
with property SupportsOnState off and no use of updateStateonserver("onOffState"..) the brightness works fine
Sun Mar 01, 2020 1:23 pm
I'm having a hard time following what you mean. Can you walk me through a specific example and the results?
Sun Mar 01, 2020 2:00 pm
when "SupportsOnState" is true
brightness follows dev.udatestateOnServer("stateonOffState" ,true/false)
Sun Mar 01, 2020 2:59 pm
What do you mean by "follows?" Can you give me a specific example, with values?
If you are wanting the On command to go to the last known brightness (before it transitioned to the OFF state) then see this thread.
Sun Mar 01, 2020 3:15 pm
In dev edit / props: "SupportsOnState" is true
dev.updatestateOnServer("onOffState" ,True) ==> brightness=100
dev.updatestateOnServer("onOffState" ,False) ==> brightness =0
dev.updatestateOnServer("brightnessLevel" ,50) does not change brightness
Sun Mar 01, 2020 3:39 pm
Did you try changing dev.onBrightensToLast as shown that other thread?
However, I don't see how that would fix this:
I don't know how / why that would fail. That should always set the brightness if it is a dimmer instance. No error logged in the Event Log?
Sun Mar 01, 2020 3:59 pm
no errors in log
and what does dev.onBrightensToLast do?
its not in the dimmer example
anyway I am happy now.. do not use SupportsOnState for dimmers then everything works -- for me
Mon Mar 02, 2020 8:37 am
I suggest you try:
dev = indigo.devices[123]
dev.onBrightensToLast = True
dev.replaceOnServer()
I don't understand why changing SupportsOnState would change the behavior (no doubt it does, but from looking at the code it is a mystery). Regardless, the instance does support the on/off state so you should leave it set to True. Note it is set to True by default for all relay and dimmer instances when it is created. I think the root problem here is probably that we should be defaulting dev.onBrightensToLast to True for new instances but we aren't and you need to explicitly do it yourself.
