Plugin interaction at the scripting shell?
Mon Nov 11, 2019 3:18 pm
My Tesla plugin keeps throwing HTTP 408 timeout errors for users, and i've finally got it throwing them on my copy.
I know that restarting the plugin will fix it for a period of time, so I'm hoping to interact with my plugin, querying values of eg self.vehicles, self.connection.auth['expiry] etc, from the scripting shell.
Can I "get in" to my plugins' context and use things like self.vehicles and self.doCommand() at all? Or plugin[com.howartp.tesla].doCommand() etc?
Basically I don't want to have to preempt what info I might need by dumping it to the log, I want to interrogate the current values of the running instance.
Peter
Mon Nov 11, 2019 3:48 pm
Re: Plugin interaction at the scripting shell?
You can't "attach" to a running plugin (I don't think). But you can do the Reload in Interactive Shell from your plugin menu and then just leave that shell open until you start seeing issues. Then you can use it to inspect away.
Mon Nov 11, 2019 3:52 pm
Ah... that'll do nicely!
Thanks, I hadn't turned on debug menus cos I don't yet use the debuggers!
Mon Nov 11, 2019 4:34 pm
You should! :wink:
Mon Nov 11, 2019 6:09 pm
I code on Windows though, so I need to work out if/how to attach a debugger from there.
My mac is essentially headless.
Tue Nov 12, 2019 10:53 am
In that case, you'll need to use pdb or PuDB (preinstalled by Indigo) which are console-based. We have a making PyCharm debugging working remotely on our todo list but it really hasn't been much of a problem thus far (your Windows use notwithstanding)... ;)
Tue Nov 12, 2019 12:09 pm
I only read the first line earlier.
Just been looking at pycharm and wondered if Indigo supported the remote debugging option so came here to ask - then noticed the rest of your reply!
It seems you just need to expose the setting for the path, so instead of looking for pycharm at localhost:12345 you can look at mySuperiorPC:12345
I think...
Tue Nov 12, 2019 3:36 pm
Perhaps - we hardcoded it because 1) it didn't require any UI changes beyond the popup to turn on debugging 2) QA was much easier to do just running locally (didn't have to set up a remote debug testing environment and then figure out the issues that would almost certainly ensue) and 3) we honestly didn't think many (any?) would need it.
We certainly didn't think a Windoze dude would! :lol:
Tue Nov 12, 2019 4:15 pm
I keep telling you - a Windows client is next on your list...!
Tue Nov 12, 2019 5:18 pm
