Dividers in UI menus/lists
Mon Sep 23, 2019 3:24 pm
berkinet offline
Is it possible to have a divider in a dynamic list. For example:
    Input 1
    Input 2
    Output 1
    Output 2
I can catch the entry in the Callback handler, but since the handler does not receive the full list, I am unsure of what to return. Returning False fails with
    TypeError: Expecting an object of type list; got an object of type bool instead
and if I return nothing I get
    TypeError: Expecting an object of type list; got an object of type NoneType instead
Again, if this were a regular static menu I could just trap the problem in the validation callback.
Thanks for any ideas.
Tue Sep 24, 2019 7:11 pm
Re: Dividers in UI menus/lists
I'm not sure I understand your question, but the dynamic callback list function (documented here) has to return the complete list/menu you want to use. So an example would be:
def myListGenerator(self, filter="", valuesDict=None, typeId="", targetId=0)
   myArray = [(“option1”, ”First Option”),(“option2”,”Second Option”)]
   return myArray
I'm not sure it will work but try this to see if it will add a separator:
   myArray = [(“option1”, ”First Option”),(“_Separator”,”_Separator”),(“option2”,”Second Option”)]
Tue Sep 24, 2019 7:43 pm
Sorry, I meant to reply to this earlier. You totally can. Here's the method I use in the Matplotlib plugin for adding a CSV source:
    def csv_source(self, type_id="", values_dict=None, dev_id=0, target_id=0):
        Construct a list of devices and variables for the CSV engine
        Constructs a list of devices and variables for the user to select within the
        CSV engine configuration dialog box. Devices and variables are listed in
        alphabetical order with devices first and then variables. Category labels
        are also included for  visual clarity.
        :param unicode type_id:
        :param class 'indigo.Dict' values_dict:
        :param int dev_id:
        :param int target_id:
        list_ = list()
        if values_dict.get('addSourceFilter', 'A') == "D":
            [list_.append(t) for t in [(u"-1", u"%%disabled:Devices%%"), (u"-2", u"%%separator%%")]]
            [list_.append((dev.id, u"{0}".format(dev.name))) for dev in indigo.devices.iter()]
        elif values_dict.get('addSourceFilter', 'A') == "V":
            [list_.append(t) for t in [(u"-3", u"%%separator%%"), (u"-4", u"%%disabled:Variables%%"), (u"-5", u"%%separator%%")]]
            [list_.append((var.id, u"{0}".format(var.name))) for var in indigo.variables.iter()]
        return list_
Screen Shot 2019-09-24 at 8.40.58 PM.png (130.5 KiB) Viewed 1797 times
Tue Sep 24, 2019 7:50 pm
Listen to Dave. He is right that the UI Name should be "%%separator%%" and not "_Separator".
Wed Sep 25, 2019 2:20 am
berkinet offline
matt (support) wrote:
I'm not sure I understand your question,...
And I probably didn't explain it very well. Here is the UI field definition from Devices.xml, the code that creates the list and and the Callback handler
<Field id="deviceSelect" type="menu" >
        <Label>Select Device:</Label>
        <List class='self' method='getDevices' />
        <CallbackMethod>getDevicesExit</CallbackMethod>
</Field>
def getDevices:
    for key in self.deviceArray:
        menuText = self.deviceArray[key]['serverName']
        menuEntry = (key, menuText)
        returnMenu.append(menuEntry)
    menuEntry = (u'--', u'-------------')
    menuEntry = (u'DIGITALINPUT', u'Digital Input')
    menuEntry = (u'DIGITALOUTPUT', u'Digital Output')
    return returnMenu
def getDevicesExit(self, valuesDict, typeId, devId):
    key = valuesDict['deviceSelect']
    if key == '--':
        errorsDict = indigo.Dict()
        errorsDict['phidgetSelect'] = "Invalid Selection"
        errorsDict["showAlertText"] = "Invalid Selection"
        return errorsDict
    elif key == ...
This creates the menu list as desired, showing the dynamic entries and then the separator and the static entries at the bottom. What I want to do is trap the case where the user selects the separator (value = "--"). Since getDevicesExit is called when there is a menu change, I thought I could trap it there and return an error indication. However, it appears that Indigo is only expecting a single dict in the return from the callback method. The code above produces no visible error message, but it does reset the menu to the original state (- Select an Item-). I suspect it does that because errorsDict is essentially an empty dict - I.e. no entries matching any fields in the UI.
So, the question is, is there a way to display an error in the case noted above? Or, should I just be content with resetting the menu and letting the user figure out what happened?
Wed Sep 25, 2019 5:36 am
If you take a look at the example code above from the Matplotlib plugin, the separator (and an attending label entry) are sent in a disabled state. This makes it so the user is unable to select the separator or the label text, so there's nothing to trap. I believe you can set each elements' value to anything you want; so long as it's valid XML.
Wed Sep 25, 2019 7:49 am
berkinet offline
DaveL17 wrote:
If you take a look at the example code above from the Matplotlib plugin, ....
Sorry. I left a window open on Matt's first post, and then responded later -- missing your post., Thanks, I think that is exactly what I wanted.
Wed Sep 25, 2019 8:24 am
No problem! If I had a nickel for every time I did that, I’d be a rich man.
Wed Sep 25, 2019 10:44 am
berkinet offline
Just curious... Is this (%%separator%% and %%disabled:foo%%) documented somewhere?
Wed Sep 25, 2019 11:15 am
Yes, but it needs to be documented somewhere besides just here. :roll:
Wed Sep 25, 2019 1:30 pm
berkinet offline
I have observed multiple list entries can contain the same value and I also noticed you and Dave both use negative numeric values in some cases, like the separator. Is that just style (my guess), or is there some semantics to that?
From the "documentation"
<Field type="menu" id="exampleMenu">
   <Label>Poll device:</Label>
   <List>
      <Option value="0">Only When Activity Detected</Option>
      <Option value="-1">%%separator%%</Option>
      <Option value="60">Every Hour</Option>
      <Option value="30">Every 30 Minutes</Option>
      <Option value="10">Every 10 Minutes</Option>
      <Option value="5">Every 5 Minutes</Option>
      <Option value="1">%%disabled:Every Minute%%</Option>
   </List>
</Field>
Wed Sep 25, 2019 6:11 pm
berkinet wrote:
...Is that just style (my guess), or is there some semantics to that?
I'm fairly certain that the value can be anything, so long as it's XML compliant. I chose to follow Matt & Jay's lead.
Sat Sep 28, 2019 12:03 pm
Yeah, that is just a notational style we use: negative values for disabled/title/separator type items.
