default value for dynamic lists
Sat Sep 14, 2019 1:34 am
berkinet offline
This question was previously asked in 2012. So, now 7 years later I am wondering if the answer might be different, also my use case is a little different.
A plugin offers the user a choice of three log level settings: info, trace, debug. This works fine in a menu (Menu item or plugin config) . However, when the menu opens I would like it to be set to the current level setting (as stored in the plugin preferences or set in plugin.py). The actual menu items are constant. I know I can provide the entire menu via a dynamic list - but I don't see any option to set the default using that approach. So, is there a way to make the default setting for a configUI menu dynamic?
Sat Sep 14, 2019 4:14 am
Re: default value for dynamic lists
From the Plugin Developer Documentation Plugin from @RogueProeliator:
   # This routine returns the initial values for the menu action config dialog, if you
   # need to set them prior to the GUI showing
   def getMenuActionConfigUiValues(self, menuId):
      self.debugLogWithLineNum(u'Called getMenuActionConfigUiValues(self, menuId):')
      if self.logMethodParams == True:
         self.debugLogWithLineNum(u'     (' + unicode(menuId) + u')')
      valuesDict = indigo.Dict()
      errorMsgDict = indigo.Dict()
      return (valuesDict, errorMsgDict)
It's a useful piece of documentation - see Plugin Developer Documenter Plugin. :)
EDIT: Actually not sure if this is answering your question?
Sat Sep 14, 2019 5:31 am
berkinet offline
autolog wrote:
...EDIT: Actually not sure if this is answering your question?
As they say in N.Z. Yeah, Nah. But thanks. The basics of dynamic menus are laid out in the Indigo Plugin Developer's Guide.
</Field>
def myListGenerator(self, filter="", valuesDict=None, typeId="", targetId=0)
   # From the example above, filter = “stuff”
   # Create an array where each entry is a list - the first item is
   myArray = [(“option1”, ”First Option”),(“option2”,”Second Option”)]
   return myArray
What is missing, at least from the documentation, is the ability to define a defaultValue for the list. I can set defaultValue in the static XML for the Field, but that is useless in this case. Also, at least in my case, the issue is the opposite of the example case: my list is static, only the default value is dynamic.
Sat Sep 14, 2019 6:13 am
I think this was actually answered in this thread from 2014: viewtopic.php?f=108&t=12530
If this menu is in the plugin preferences, then you want:
   def getPrefsConfigUiValues(self):
      prefsConfigUiValues = self.pluginPrefs
# set the default for the preference key here
      return prefsConfigUiValues
Sat Sep 14, 2019 6:51 am
berkinet offline
I had seen that topic but didn't get how to apply it to what I am doing. After going over it three more times, I got it. For anyone else in the same situation, here is the part I missed...
To dynamically set the defaultValue for a dynamic list (and possibly any list) you need to create a method with the specific name of getPrefsConfigUiValues
        """ preset the default value for a configUI list """
        prefsConfigUiValues['field_name'] = some_default_value
Then, create the actual list statically or dynamicaly as you choose. In other words, the dynamic setting of defaultValue for a dynamic list (menu) is independent of the creation of the list.
BTW, I assume this approach is what Jay referred to as jiggery-pokery
Sat Sep 14, 2019 6:55 am
Slight correction.
berkinet wrote:
To dynamically set the defaultValue for a dynamic list (and possibly any list) in the plugin preferences, you need to create a method with the specific name of getPrefsConfigUiValues
This routine is specific to the PluginConfig.xml. There are similar routines for dynamic lists in the other xml files.
Also, you should really check to see if the value already exists before you set it. Your code as written will overwrite an existing selection.
