Another issue validateDeviceConfigUi()
Wed Sep 04, 2019 8:37 am
berkinet offline
This is baffling me. validateDeviceConfigUi() receives valuesDict for a new device, changes the value of one entry, and returns valuesDict. If I log valuesDict just before returning it, I can see the entry in question has been changed. But, when the device is created, the property has the original, blank, value. Then, if I just open the device, click edit, then save, the device property is correctly saved.
Wed Sep 04, 2019 9:04 am
Re: Another issue validateDeviceConfigUi()
Can you copy/paste your validateDeviceConfigUi() method so I can see specifically what it is doing (and returning)?
Wed Sep 04, 2019 9:08 am
berkinet offline
      func = inspect.stack()[0][3]
      self.logger.debug(u"%s: called with typeId=%s, devId=%s, and valuesDict=%s.", func, typeId, devId, valuesDict)
      errorsDict = indigo.Dict()
      if not valuesDict['outletNum'] or valuesDict['outletNum'] == None or valuesDict['outletNum'] == "":
         valuesDict['outletNum']   = "00"
      if not valuesDict['childId'] or valuesDict['childId'] == None or valuesDict['childId'] == "":
         valuesDict['childId']   = str(valuesDict['deviceId']) + valuesDict['outletNum']
      # If we have been asked to re-initialize this device...
      if ('initialize' in valuesDict and valuesDict['initialize']):
         self.initializeDev(valuesDict)
      valuesDict['newDev'] = False
      valuesDict['initialize'] = False
Note initialize is not being called
Wed Sep 04, 2019 9:17 am
I just tried it in a testing plugin and am not seeing what you are (in mine the property updated).
How specifically are you inspecting the value when you see the wrong/blank value?
Wed Sep 04, 2019 9:19 am
berkinet offline
...How specifically are you inspecting the value when you see the wrong/blank value?
>>> print indigo.devices[1555438002] # "new device"
And, it throws an error in deviceStartComm
Wed Sep 04, 2019 9:51 am
What do you mean it throws an error in startComm? That might actually be what is causing it to fail to update...
Wed Sep 04, 2019 9:53 am
berkinet offline
It throws the error because it tries to add 1 to the value of dev.pluginProps{'outletNum']
Wed Sep 04, 2019 10:01 am
I think you have something else going on here. I stripped it down to this:
      valuesDict["pollRate"] = 123
      return (True, valuesDict)
   def deviceStartComm(self, dev):
      indigo.server.log("pollRate: {}".format(dev.pluginProps.get("pollRate", "not defined")))
and it works as expected.
Wed Sep 04, 2019 10:09 am
berkinet offline
I think you have something else going on here...
I am pretty sure you are right. But I sure as heck can't figure out what. I'll pound on it for a while. Thainks
Wed Sep 04, 2019 10:10 am
RogueProeliator offline
Maybe irrelevant if you are handling it, but I might point out you are setting the initial value of outletNum to a string not an integer...
Wed Sep 04, 2019 10:11 am
berkinet offline
Well, I was summarizing... it actually does foo = int(bar) :wink:
Wed Sep 04, 2019 10:13 am
If you posted the actual code (for both methods) someone else might be able to spot the error.
Wed Sep 04, 2019 10:16 am
berkinet offline
The problem is 100% clear the property has no value after finishing creation. That missing value causes the error I mentioned. If I re-edit the same exact device, there property gets set. I can post before and after device settings.
Wed Sep 04, 2019 10:46 am
berkinet offline
I think I may have found the cause... The field I was having problems setting was not visible at the time the new value was returned to the ConfigUI. So, my guess is, either it was not updated because it was not visible, or it was not waved when the ConfigUI was closed. As soon as I made the field visible, the problem went away.
