Menuitems (and other) issues
Sun Sep 01, 2019 10:26 am
berkinet offline
I have run into a couple of unrelated issues. Could be bugs, but more likely cockpit errors.
  1. In a Menuitem ConfigUI I have the following field described
    <Field id="multiPlug" type="checkbox" readonly='YES' visibleBindingId="displayOk"  visibleBindingValue="true" >
            <Label>2 or more outlets:</Label>
    </Field>
    It displays, but it is not readonly. That is, the user can still click the checkbox to change the display. There is no action attached, so the effect is only cosmetic. This is happening on all checkbox fields on the UI. But, readonly is properly respected for textfields
  2. I have a callback method that receives a dict, valuesDict. I would like to log the entries in that dict, but when I do
    self.logger.info("Device data for %s:\n%s", device, valuesDict)
    I get a dictionary name as the first line of output...
      TP-Link Device                  Device data for device:
         UiValuesDict : (dict)
         actionButton :  (string)
         address : 192.168.5.113 (string)
    This isn't a huge issue since I want to remove some entries and add some labels anyway. But, I was just wondering if there were a way to suppress that first line.
Thanks for any ideas, suggestions, etc.
Sun Sep 01, 2019 11:31 am
Re: Menuitems (and other) issues
Probably isn't documented, butI believe checkbox control types ignore the readonly attribute. Readonly is only used (Jay correct me if I'm wrong) for the text field control types.
I can help you with the 2nd question though. Indigo uses its own internal/special dictionary type which as you noticed logs (via str()) differently than the python one. In this case you can first cast it to a python dict type if you want its str() formatted result:
self.logger.info("Device data for %s:\n%s", device, dict(valuesDict))
Sun Sep 01, 2019 11:35 am
I was just replying when I saw Matt's reply. It's either a documentation bug (it should apply to fewer field types than the docs say) or it's a code bug. My spider sense is tingling about this for some reason, so I think this might have come up before. We'll look into it.
Sun Sep 01, 2019 11:36 am
berkinet offline
Thanks Matt. BTW, readonly actually IS documented tor checkbox types. The docs say it does support the option. :roll: No big deal either way, I was just curious as to why it didn't work.
Enjoy labor day. You two guys certainly deserve it.
Sun Sep 01, 2019 11:38 am
berkinet offline
jay (support) wrote:
... My spider sense is tingling about this for some reason, so I think this might have come up before. We'll look into it.
Funny, I had a sort of deja vu too. It wouldn't surprise me at all if you do find a previous reference if it was in response to something I posted. :roll: (rolling eyes at myself this time)
Sun Sep 01, 2019 11:44 am
berkinet offline
...My spider sense is tingling about this for some reason, so I think this might have come up before. We'll look into it.
https://forums.indigodomo.com/viewtopic.php?f=108&t=21409&hilit=checkbox+readonly and I wasn't involved
Sun Sep 01, 2019 7:48 pm
Thought it sounded familiar... :)
