Error (client) illegal string for list ID (ignoring):
Mon Aug 12, 2019 4:14 pm
this error occurs when I open device edit.
checked all id="xxx", they are all plain ascii
a more detailed error message would be really helpfu - like Line # in plugin or devices.xml..
any idea where to look?
Mon Aug 12, 2019 4:57 pm
Re: Error (client) illegal string for list ID (ignoring):
Not sure if this is helpful but based on when that error is logged: somewhere there is a comma or semicolon where there shouldn't be.
Mon Aug 12, 2019 6:12 pm
Make sure you're not starting any with a numeral. That's verboten.
Mon Aug 12, 2019 7:11 pm
So this can be any menu item?
Or any item?( there are >> 100 in the device list
Mon Aug 12, 2019 7:40 pm
<<?xml version="1.0"?>
<Devices>
<Device type="custom" id="plots">
        <Name>abc</Name>
<ConfigUI>
<Field id="abc"   type="label" >    <Label> text  </Label>     </Field>
</ConfigUI>
</Device>
</Devices>
this device.xml creates the error.. actually 2..
that can not be it..
Mon Aug 12, 2019 8:08 pm
See if removing the space before the 't' gets it working. From:
<Label> text
to:
<Label>text
Mon Aug 12, 2019 8:19 pm
<Devices>
   <Name>abc</Name>
   <ConfigUI>
      <Field id="xyz"   type="label">    <Label>jkl</Label>     </Field>
   </ConfigUI>
</Device>
</Devices>
still same problem
Tue Aug 13, 2019 5:53 am
I just copy/pasted in the <Device> from the XML above:
   <Name>abc</Name>
   <ConfigUI>
   </ConfigUI>
</Device>
into one of my example plugins, and I'm not getting any error when I create a device from it (and go into its settings dialog). Are you sure the problem is coming from the XML file?
Tue Aug 13, 2019 5:55 am
Yes it must be in the python code or in the props data.
... ?? How to search for it? ?
Tue Aug 13, 2019 6:00 am
The Indigo side of the code is inspecting what it wants to be a comma delimited list/array that might (or might not) be a string. It doesn't like that there is a semicolon or comma (or maybe a leading space) in it. I think process of elimination by commenting out code is going to be the way to go.
Tue Aug 13, 2019 6:10 am
thats going to be difficult ... > 10k lines, can't just eliminate code..
May be a direction where to search for it:?
it only happens when a device (happens to all) is edited. If there are NO calls to filters or callbacks in device.xml which code in the plugin is used?
Tue Aug 13, 2019 6:47 am
I checked the props:
printed w:
indigo.server.log("   "+unicode(prop)+"  >>>"+unicode(props[prop])+"<<<" )
only one ";" in one of the props - and that is a text field:
lineOffsetMultHelp  >>>offset: shift up down, Multiply value; for a straight line use OFFSET for left value and MULTIPLIER for slope you can use variable %%v:id or name%%<<<
And one list w data:
MHDFormat  >>MHDFormat : (list)
     Item :  (string)
     Item :  (string)
     Item : %d (string)<<
Tue Aug 13, 2019 9:02 pm
If you have a plugin and steps to reproduce the problem then zip them up and email them to me. I can run it in the debugger and get more details about where it is occurring.
