This is probably a stupid programming error
Wed Aug 07, 2019 3:57 pm
But I can't see it.
Python script code:
mqttPlugin = indigo.server.getPlugin("com.flyingdiver.indigoplugin.mqtt")
if mqttPlugin.isEnabled():
    props = {
        'message_type':"#Test#"
    data = mqttPlugin.executeAction("fetchQueuedMessage", deviceId=1867973662, props=props, waitUntilDone=True)
Log output:
Aug 7, 2019 at 5:56:28 PM
   Script Error                    embedded script: plugin does not have a <CallbackMethod> specified for action id fetchQueuedMessage
     embedded script, line 6, at top level
InvalidParameter: plugin does not have a <CallbackMethod> specified for action id fetchQueuedMessage
Actions.xml:
    <Action id="fetchQueuedMessage">
        <CallbackMethod>fetchQueuedMessageAction</CallbackMethod>
        <ConfigUI>
            <Field id="fetch_messageType" type="textfield">
            </Field>
        </ConfigUI>
    </Action>
plugin.py:
    def fetchQueuedMessageAction(self, action, dev, callerWaitingForResult):
        messageType = action.props["message_type"]
        queue = self.queueDict.get(messageType, None)
        if not queue or queue.empty():
            return None
        self.logger.debug(u"{}: queueMessageForDispatchAction, queue = {} ({})".format(device.name, messageType, queue.qsize()))
        return queue.get()
Where did I mess up?
Wed Aug 07, 2019 4:14 pm
Re: This is probably a stupid programming error
Well isn't that interesting. If I change Actions.xml to:
        <Name>Fetch Queued Message</Name>
        <ConfigUI>
                <Label>Message Type:</Label>
            </Field>
        </ConfigUI>
    </Action>
Then it works. Or at least I don't get the same error.
I originally didn't have <Name> and <Label> because I was trying to hide this from the Actions list, as I was intending it to be used from scripts only.
Now I get this error:
   Script Error                    embedded script: NameError -- global name 'device' is not defined
StandardError: NameError -- global name 'device' is not defined
Which is interesting because I don't have that name in the script at all. But I think I know where it's coming from. I'll work on that.
Wed Aug 07, 2019 4:22 pm
Ah. It's actually repeating the error from the other end of the connection. But it was reporting it as coming from the script, not the plugin. When I set wait to False, then it was reported correctly.
All fixed now.
Sometimes you just need to talk to yourself to figure things out.
:P :P :P :P
Wed Aug 07, 2019 4:25 pm
I know the feeling, and it (talking to oneself) isn't a bad technique at all. :lol:
Wed Aug 07, 2019 4:29 pm
Glad you sorted it cos I’m lost!
However, what’s the purpose of having an Action listed in Actions.xml at all, if you’re not intending it being shown in the UI?
Isn’t that just what normal folk would call a “function” in your script...?
Wed Aug 07, 2019 4:34 pm
Needed it to be in Actions.xml so it would be callable from another plugin or a script.
Wed Aug 07, 2019 5:28 pm
:P :P :P :P
I often find that just posting about it is all I need to spot the problem. :D
Wed Aug 07, 2019 5:34 pm
<Action id="fetchQueuedMessage" uiPath="hidden">
That'll do it. Yeah, yeah, yet another developer doc update fail... ;)
Wed Aug 07, 2019 6:23 pm
I thought it would be this, which didn't work:
<Action id="fetchQueuedMessage" hidden="true">
Wed Aug 07, 2019 6:29 pm
OK, that worked.
