Symbolic link for plugin development
Wed Aug 07, 2019 12:33 pm
joshh385 offline
I feel like I'm missing something very simple/obvious here. I upgraded my Mac recently and am having to setup some of my development environment pieces again. I had previously setup a symbolic link for a plugin I was working on so that indigo would move the link when the plugin is enabled/disabled and not the files themselves, and that was working. When I set it up now though I get the link in the plugin directory, and if I enable/disable the plugin it seems to be impacting the actual files that are stored elsewhere (where the link points).
I also thought I remembered a little write-up for setting up a plugin development environment from the last time I did this, but now I can't find it. Does anyone have something along those lines, or any tips on getting that link setup for the plugin?
Wed Aug 07, 2019 1:11 pm
Re: Symbolic link for plugin development
I do that all the time. It has to be a symbolic link created in the Terminal. A Finder alias won't work.
In Terminal:
cd <disabled plugin directory>
ln -s <path to plugin>
Wed Aug 07, 2019 1:25 pm
joshh385 offline
Good to know I'm not completely losing it...
Did this at the terminal:
MacMini:Plugins (Disabled) josh$ ln -s "/Users/josh/Public/Indigo Plugins/_packaged/jh.sensibo.indigoPlugin"
And I see jh.sensibo.indigoPlugin show up in the Plugins (Disabled) directory.
I enable the plugin in Indigo and it does start, but it leaves the symlink in the disabled directory, and creates a copy of the plugin in the Plugins directory with a timestamp added to the name
Then if I disable it that copy is moved to disabled, and subsequent enable/disable operations appear to just move the copy back and forth and don't pickup changes that I made to the original located over at /Users/josh/Public/Indigo Plugins/_packaged, where the symlink points
Wed Aug 07, 2019 2:16 pm
What does the Indigo log say when you restart it?
Wed Aug 07, 2019 2:23 pm
Shut down IndigoServer. Remove all existing aliases and copies in all the Plugins folders. Recreate the alias. Restart Indigo.
I think that'll sort it out. Make sure that you're creating the symlink under the same user account that is running the server.
Wed Aug 07, 2019 5:48 pm
joshh385 offline
This did sort it out. Seems to be working as expected now. Now I'm not sure - I think I tried all these steps before - but the missing piece may have been the stopping of the server. I bet when I ended up removing all the copies and aliases in the plugin directory I only close the indigo app and didn't actually stop the server. Doh! Thanks for the help
