GitHub to indigo store problem
Mon Jan 21, 2019 7:28 pm
getting email and plugin store does NOT copy from GitHub..
Indigo failed to add/update a release from your Github repo. Plugin release tagged with version '7.100.267' doesn't match the Info.plist version '7.99.266'.
Plugin: piBeacon
Github Release URL: https://github.com/kw123/pibeacon/relea ... v7.100.267
the info.plist file is correct, downloaded .zip from GitHub and looked at info.plist file there
<dict>
   <key>PluginVersion</key>
   <string>7.100.267</string>
   <key>ServerApiVersion</key>
   <string>2.0.0</string>
   <key>IwsApiVersion</key>
   <string>1.0.0</string>
This is happening with 2 plugins now.. may be it is early Alsheimer... but I tried several times, double checked the version numbers.. no spaces in the number fields ..
'7.99.266'. is the previous version.
any votes? Is it Alsheimer or bug
Mon Jan 21, 2019 7:37 pm
Re: GitHub to indigo store problem
Look at the code that's actually committed for release 7.100.267. https://github.com/kw123/pibeacon/commi ... 6321483d4e
The Info.plist in the commit doesn't match.
I suspect you have a commit on your local system that was not pushed to GitHub.
Mon Jan 21, 2019 7:45 pm
did the push up
<plist version="1.0">
<dict>
   <string>piBeacon</string>
   <key>CFBundleIdentifier</key>
   <string>com.karlwachs.piBeacon</string>
   <key>CFBundleVersion</key>
   <key>CFBundleURLTypes</key>
   <array>
      <dict>
         <key>CFBundleURLName</key>
         <string>http://forums.indigodomo.com/viewforum.php?f=164</string>
      </dict>
   </array>
</dict>
</plist>
from GitHub.
Mon Jan 21, 2019 7:47 pm
Now you need to retag the version and redo the release. Your latest commit isn't the one the release references.
Mon Jan 21, 2019 7:54 pm
redid everything now its works .. must be early onset ..
Mon Jan 21, 2019 7:55 pm
Process problem. You need to do everything in the exact right order. And the fact that the .zip file you upload has nothing to do with the store. It's not required at all.
Mon Jan 21, 2019 8:41 pm
I read somewhere the zip is a “should do”.
Better for the download user.
Mon Jan 21, 2019 8:42 pm
No argument there, but it's not "required" for the process. The store software doesn't care if it's there or not.
Mon Jan 21, 2019 9:32 pm
For now. That’s going to change...
Mon Jan 21, 2019 9:33 pm
so zip it or not?
Mon Jan 21, 2019 9:35 pm
kw123 wrote:
so zip it or not?
Zip it. There's no reason not to. My only point was that you were comparing what was in the zip file against the error message, when (for now) it's not even part of the equation.
