Best way to keep track of Plugin versioning; code updates
Thu Nov 15, 2018 5:15 am
GlennNZ offline
Hi all,
Interested in thoughts as to ‘best practice’ to keep track of plugin version. e.g alllowing updating / special updates to be run when new version has just been installed? (as opposed to restarted/reloaded)
Hidden pluginprefs version?
Versus file saved info?
Seem to the two approaches that would make sense/have been used. Leaning towards the first approach from simplicity standpoint.
But interested in any pointers?
Tah
Glenn
Thu Nov 15, 2018 8:23 am
RogueProeliator offline
Re: Best way to keep track of versioning, when special updat
That is what I do and has served me well... it just checks the version on load and calls the upgrade routine. That routine then needs to check the old version and process any updates going forward, keeping in mind that the user may have skipped versions on you (in other word, may have a couple of "versions" of upgrade code to run). Once complete, it updates the pref tracking the last version.
Adam
Thu Nov 15, 2018 9:40 am
I wouldn't spend a lot of time on adding plugin update management features. 7.3 will see some version notification improvements in the Mac Client, and we'll eventually get to full upgrade management built-in.
I'd recommend spending time on plugin features, documentation, etc. - things that we can't really help you with.
Thu Nov 15, 2018 9:44 am
If you're talking about changes to devices, events, and actions that your plugin supports, then using an object version number is probably the right way to go - you can then just build a table of conversions that need to be applied to any given version to upgrade it to the latest.
Thu Nov 15, 2018 10:25 am
Yeah, that is what I was talking about, but at the plugin level - setting up new features / properties, etc. I do something similar at the device level to detect upgrades needed there. That doesn't take any time at all to implement.
Thu Nov 15, 2018 5:18 pm
GlennNZ offline
Adam
Great - thanks all for the advice.
Have got on and implemented.
Glenn
