Z-Wave Raw Commands?
Sat Oct 27, 2018 7:00 am
In the Indigo documentation, in the section Z-Wave hooks and improvements, it shows the following detail:
# Send a Z-Wave command
indigo.zwave.sendRaw(device,        # device arg is optional - if not specified you must specify a nodeId
               nodeId,              # optional - if not specified you must specify a device
               endpoint,            # optional - if a nodeId is specified and supports multiple endpoints
               cmdBytes,
               sendMode,            # 0: immediate, 1: immediate first, if no ACK wait for wake, 2: wait for wake
               waitUntilAck         # defaults to True if not specified
There is no example code to show how to format the call. I am unclear as to how you skip past the optional fields. The various things I have tried have not resulted in success. :|
All the various calls in that section could do with specific examples. :wink:
Some guidance would be much appreciated. :)
Sat Oct 27, 2018 7:04 am
Re: Z-Wave Raw Commands?
In Python, if you want to skip parameters, you have to name anything after that.
cmdString = "XYZ"
indigo.zwave.sendRaw(myDevice, cmdBytes = cmdString, sendMode = 0, waitUntilAck = False)
or
cmdString = "XYZ"
indigo.zwave.sendRaw(nodeId = 4, cmdBytes = cmdString, sendMode = 0, waitUntilAck = False)
Sat Oct 27, 2018 8:49 am
Thanks Joe :D
My test code looks like this:
# Send a Z-Wave command - open valve to 50%
cmdString = [0x26, 0x01, 0x32]
indigo.zwave.sendRaw(device = dev, cmdBytes = cmdString, sendMode = 1)
Thanks again for your help :)
Fri Mar 27, 2020 3:54 pm
dduff617 offline
anyone know how to see the results returned from the z-wave command? does that make sense for this function? ... i recall you could get these from indigo.sendRawExtended command using the replyBytes property of the returned result.
Fri Mar 27, 2020 4:28 pm
Unfortunately, for Z-Wave commands the replies are broadcast back asynchronously (except the ACK), so the only way to catch them would be in a plugin that defines the callback to receive all Z-Wave commands. Extended Insteon commands are different and the Indigo Server is able to send those replies to the caller.
