Initialize fields in MenuItem dialog
Sat Oct 20, 2018 11:36 am
rbdubz3 offline
I am putting together a MenuItem for a plugin. The MenuItem has a main 'list' of values that selected, upon which the dialog loads a number of additional fields. I have most of this working properly. However, I am not sure how to populate the dialog upon initialization, when a user first selects the MenuItem for the plugin..
Here is a quick excerpt from my MenuItems.xml:
   <MenuItem id="saveScene">
      <Name>Edit Scenes...</Name>
      <CallbackMethod>saveScene</CallbackMethod>
      <ButtonTitle>Save</ButtonTitle>
      <ConfigUI>
         <Field id="sceneId" type="menu" defaultValue="">
            <Label>Scene:</Label>
            <List class="self" method="sceneListGenerator"></List>
            <CallbackMethod>scenesListItemSelected</CallbackMethod>
         </Field>
         <Field id="sceneIdLabel" type="label" alignWithControl="true" fontSize="small" fontColor="darkgray">
            <Label>Select the Scene preset for storing the configuration. Scenes with an asterisk (*) next to them have data already saved in them. Selecting one of these Scenes will overwrite the data saved.</Label>
         </Field>
         <Field id="sceneName" type="textfield" defaultValue="">
            <Label>Scene Name:</Label>
         </Field>
         <Field id="sceneNameLabel" type="label" alignWithControl="true" fontSize="small" fontColor="darkgray">
            <Label>Assign a name to this Scene.</Label>
         </Field>
      </ConfigUI>
   </MenuItem>
So far, all of the methods are functioning ok - saveScene, sceneListGenerator, and scenesListItemSelected... The logic for populating the 'valuesDict' in the scenesListItemSelected method works fine after the dialog is displayed and I select different items in the main 'Scene' list..
Any tips on how to populate the MenuItem fields upon dialog initialization is appreciated
I automate because I am lazy :D - My Plugins: https://forums.indigodomo.com/viewforum.php?f=309
Sat Oct 20, 2018 11:45 am
Re: Initialize fields in MenuItem dialog
Take a look at this excellent plugin: Plugin Developer Documenter Plugin
It may help show you what's needed :)
Sat Oct 20, 2018 11:50 am
I think you need this:
def getMenuActionConfigUiValues(self, menuId):
      valuesDict = indigo.Dict()
      errorMsgDict = indigo.Dict()
# fill in the valuesDict here with your pre-fill data
      return (valuesDict, errorMsgDict)
Sun Oct 21, 2018 8:33 am
rbdubz3 offline
thanks for the inputs.. the 'getMenuActionConfigUiValues' did the trick.. Guess I missed this in the Indigo documentation somewhere
