Modify Existing Plugin for Frigidaire Dehumidifier
Mon May 21, 2018 6:08 am
I just picked up a new Frigidaire dehumidifier that has built-in WiFi for connection to Alexa (and whatnot). It's controllable via a standalone app and I was hoping I might be able to leverage one of the existing plugins to control it. It works remotely, so I suspect it requires cloud. There's only a few settings to control;
Power (on/off)
Target Humidity (up/down)
Fan Speed (high/low)
Timer (set 30 min increments/clear)
If copying an existing framework won't work, I'd appreciate a few pointers or online sources to learn how to go about starting from scratch. I have Wireshark up and running, but don't really know how to use it.
Thanks in advance!
Mon May 21, 2018 9:33 am
Re: Modify Existing Plugin for Frigidaire Dehumidifier
Have you searched on Github for any existing stuff that can be incorporated or at least used as a source of information?
Mon May 21, 2018 9:42 am
Yeah, I found stuff for homebridge integration and for IR commands, but I didn't see anything that was straight-up Python.
I don't mind the learning exercise if I need to go that route.
