Help with enabledBindingId not functioning
Thu May 10, 2018 6:56 am
vtmikel offline
I'm having trouble with this attached form.
The "Applies to all devices" is supposed to disable the "Devices this filter applies to" when enabled. I had this working by adding the properties of the listbox:
enabledBindingId="filterAllDevices" enabledBindingNegate="true"
This worked fine. However, as I built the form further, I needed to have the checkbox and listbox visibility bound to another control, so I added to both controls:
visibleBindingValue="edit,add" enabledBindingId="editMode"
This broke the enabled binding for the "devices this filter applies to" listbox. The visibility binding works fine for both. The enabled binding works when the visible binding is removed, and immediately stops working when I add it back in.
Screen Shot 2018-05-09 at 4.00.09 PM.png (484.16 KiB) Viewed 1216 times
Thu May 10, 2018 9:05 am
Re: Help with enabledBindingId not functioning
Combining visible and enabled bindings is probably something best avoided (there are definitely limitations). You may be able to use the dynamicReload flag with a common method call such that whenever a button or menu item is changed the method is called with the new values - that would enable you to set flags as necessary (use hidden checkboxes for instance to control behavior). Without seeing a complete ConfigUI (preferably a short example of what you're trying to do) it's hard to know for sure.
Thu May 10, 2018 9:26 am
vtmikel offline
If there's a way to programmatically control the hidden property, that would probably solve my issue. Is there an example of this you can point me to?
Thu May 10, 2018 10:26 am
Yes
Set the hiddenid to a check box
Then in program set that checkbox to true/false
I have in one of my plugins >>10 of this to switch certain fields visible / hidden.
then you need to have a central method that is called by the buttons the users click
That method then will set visible on/off for all
Thu May 10, 2018 12:14 pm
here the hidden indicators in eg devcie.xml
<Field id="ExpertsAndPlots"        type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="ExpertsAndLines"        type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="selectLinesOK"          type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="DefineLinesANotSelect"  type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="DefineLinesASelected"   type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="DefineLinesBNotSelect"  type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="DefineLinesBSelected"   type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="showFunc"               type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="fontsGNUONOFF"          type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="fontsMATONOFF"          type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="TimeseriesAndPlots"     type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="showBins"               type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="showBinsS"              type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="showXscale"             type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="showY2scale"            type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="showRGBBackground"      type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="showRGBText"            type="checkbox" defaultValue="true"  hidden="yes"> </Field>
<Field id="polarLineText"          type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="polarPlotText"          type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="amPm"                   type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="leftRight"              type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="showExtraText"          type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="showNotScatter"         type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="showNotScatterS"        type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="showNotScatterC"        type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="showSmooth"             type="checkbox" defaultValue="false" hidden="yes"> </Field>
<Field id="showLineShift"          type="checkbox" defaultValue="false" hidden="yes"> </Field>
used like this in eg devcie.xml:
<Field enabledBindingId="selectLinesOK" visibleBindingId="showLineShift" visibleBindingValue="true" id="lineShift" type="menu" defaultValue='0' tooltip="1 would show yesterdays data today,   365 would show last years data today">....
then set like this:
    def setViewOnOff(self, valuesDict):
            if valuesDict["DefinePlots"]:
                if valuesDict["PlotType"] =="dataFromTimeSeries":
                    valuesDict["TimeseriesAndPlots"] = True
                    valuesDict["TimeseriesAndPlots"] = False
                if valuesDict["XYvPolar"] =="xy" and valuesDict["ExpertsP"] == True and valuesDict["PlotType"] == "dataFromTimeSeries":
                    valuesDict["showBinsS"] = True
                    valuesDict["amPm"] = True
                    valuesDict["showBinsS"] = False
                    valuesDict["amPm"] = False
                if valuesDict["PlotType"] =="dataFromTimeSeries" and valuesDict["XYvPolar"] =="polar":
                    valuesDict["polarPlotText"] = True
                if valuesDict["PlotType"] !="dataFromTimeSeries" or valuesDict["XYvPolar"] =="polar":
                    valuesDict["showXscale"] = True
                    valuesDict["showXscale"] = False
                if valuesDict["XYvPolar"] =="polar":
                    valuesDict["showY2scale"] = False
                    valuesDict["showY2scale"] = True
                    valuesDict["polarPlotText"] = False
                if valuesDict["ExpertsP"]:
                    valuesDict["showRGBBackground"] = True
                    valuesDict["showRGBText"] = True
                    valuesDict["ExpertsAndPlots"] = True
                    valuesDict["showBins"] = True
                    valuesDict["showExtraText"] =True
                    if  self.gnuORmat == "gnu":
                        valuesDict["fontsGNUONOFF"] = True
                        valuesDict["fontsMATONOFF"] = False
                        valuesDict["fontsMATONOFF"] = True
                        valuesDict["fontsGNUONOFF"] = False
                    valuesDict["ExpertsAndPlots"] = False
                    valuesDict["showBins"] = False
                if len(valuesDict["ExtraText"]) >0:
                valuesDict["showRGBBackground"] = False
                valuesDict["showRGBText"] = False
                valuesDict["showExtraText"] =False
                valuesDict["showNotScatter"] =False
                valuesDict["showNotScatterS"] =False
                valuesDict["showNotScatterC"] =False
                valuesDict["showLineShift"] =False
            if valuesDict["DefineLines"]:
#               valuesDict["showRGBLine"] = True
                    if valuesDict["XYvPolar"] =="xy":
                        valuesDict["showFunc"] = True
                        valuesDict["showFunc"] = False
                    if valuesDict["lineFunc"] =="E" or valuesDict["showFunc"] =="S" or valuesDict["showFunc"] =="C":
                    valuesDict["ExpertsAndLines"] = True
                    if  valuesDict["lineFunc"] =="E" or valuesDict["lineFunc"] =="S":
                        valuesDict["showSmooth"] = False
                        valuesDict["showNotScatter"] = False
                        valuesDict["showNotScatterS"] = True
                    elif valuesDict["lineFunc"] =="C" :
                        valuesDict["showNotScatterC"] = True
                        valuesDict["showSmooth"] = True
                        valuesDict["showNotScatter"] = True
                    valuesDict["showLineShift"] =True
                    if "StraightLine" in  valuesDict and unicode(valuesDict["StraightLine"]).upper()=="TRUE" or  valuesDict["selectedLineSourceATEXT"].find("-event") >-1:
                        #self.ML.myLog("Plotting",unicode(valuesDict))
                        if valuesDict["StraightLine"] :
                    if self.showAB == "SAB":
                        valuesDict["DefineLinesASelected"] =True
                        valuesDict["DefineLinesANotSelect"] =False
                        valuesDict["DefineLinesBSelected"] =True
                        valuesDict["DefineLinesBNotSelect"] =False
                    if self.showAB == "SA":
                        valuesDict["DefineLinesBSelected"] =False
                    if self.showAB == "NSAB":
                        valuesDict["DefineLinesASelected"] =False
                        valuesDict["DefineLinesANotSelect"] =True
                        valuesDict["DefineLinesBNotSelect"] =True
                    if self.showAB == "NSA":
                    valuesDict["ExpertsAndLines"] = False
                    valuesDict["DefineLinesBNotSelect"] = False
                    valuesDict["DefineLinesBSelected"] = False
                    if str(valuesDict["lineFunc"]) =="E" or str(valuesDict["lineFunc"]) =="S" or str(valuesDict["lineFunc"]) =="C":
                        if self.showAB.find("N")>-1:
                    valuesDict["leftRight"] = True
                    valuesDict["polarLineText"] = True
                    valuesDict["textPolarL1"] ="LineA for radius and LineB for angle"
                    valuesDict["leftRight"] = False
                valuesDict["DefineLinesANotSelect"] = False
                valuesDict["DefineLinesASelected"] = False
                valuesDict["showRGBLine"] = False
                valuesDict["showNotScatterS"] = False
                valuesDict["showNotScatterC"] = False
            return valuesDict
        except  Exception, e:
            self.ML.myLog("all","Line '%s' has error='%s'" % (sys.exc_traceback.tb_lineno, e))
#         self.ML.myLog("all",unicode(valuesDict))
        return valuesDict
called by
    def ExpertOnOffPlotCALLBACK(self, valuesDict=None, typeId="", targetId=0):
        valuesDict = self.setViewOnOff(valuesDict)
        return valuesDict
or
    def pickExistingOrNewLineCALLBACK(self,  valuesDict=None, typeId="", targetId=0):         # store user input and set other parameters used later
        self.CurrentLineNo   = "0"
        self.addLine      = False
        nPlot            = str(indigo.devices[targetId].id)
                theDefaultColNumber =int(self.PLOT[nPlot]["lines"][self.CurrentLineNo]["lineToColumnIndexB"])               # get the last entry
                if theDefaultColNumber >0:
                    self.showAB=     "SAB"
                    if self.currentPlotType =="dataFromTimeSeries":
                        valuesDict["selectedLineSourceBTEXT"]   = self.listOfSelectedDataColumnsAndDevPropName[theDefaultColNumber][1]
                        valuesDict["selectedLineSourceB"]       = self.listOfSelectedDataColumnsAndDevPropName[theDefaultColNumber][0]
        valuesDict =self.setViewOnOff(valuesDict)
...        return valuesDict
probably a bit more complex than you need, but the principle should be clear
Wed May 16, 2018 6:59 am
vtmikel offline
Thanks for the suggestions. I was able to get something configured to work.
