MenuItem ConfigUI saving/loading of values
Tue Mar 27, 2018 12:27 pm
vtmikel offline
I need help with something I've never done before in a plugin and I couldn't find an example to look at.
I want to build a MenuItem with a ConfigUI that essentially contains advanced configuration values for my plugin. I noticed a few things:
Question 1: The fields in MenuItems ConfigUI don't seem to save the values automatically like they do in the Plugin Configuration...
Question 2: If I have to save the values of the fields in the MenuItem configUI myself, I can do that in the CallbackMethod, but where and how would I load those values back up, particularly when I need to change the selected item of lists or menus?
Thanks.
Tue Mar 27, 2018 12:48 pm
Re: MenuItem ConfigUI saving/loading of values
First question - why a separate menu item and not just an advanced section of the normal config dialog? Perhaps a section hidden by an "Advanced" checkbox?
Tue Mar 27, 2018 12:51 pm
vtmikel offline
I'll go this way if I need to. I already had a fairly advanced configuration so consider this "level 3", but still something that every user will need to access. This plugin has no devices, so everything will be in the plugin menu. This was my attempt to break it up.
Tue Mar 27, 2018 12:57 pm
Where would it save them to? It's not the plugin config dialog, so it doesn't know you're trying to save those fields as pluginPrefs...
You could add them to the pluginPrefs yourself, then fetch them as you would any other pluginPrefs data.
For example, in one of my plugins I save a list of seen messages to the pluginPrefs:
            indigo.activePlugin.pluginPrefs[u"readMessages"] = newMessageList
And read it back in later:
        oldMessageList = indigo.activePlugin.pluginPrefs.get(u"readMessages", indigo.List())
Tue Mar 27, 2018 12:59 pm
vtmikel offline
That's what I thought. And, for a menu or list, how do I tell the UI which values should be selected?
Tue Mar 27, 2018 1:00 pm
This is what I do.
Have a look at the Multitool plugin for an example. Look specifically at the Subscribe to Changes tool. The user manages those prefs through a menu config UI and the plugin saves them to hidden fields in the plugin config.
Works really well.
Tue Mar 27, 2018 1:01 pm
I don't think I understand the question. If you have a menu item in the ConfigUI, you either hardcode a list into the Menu.xml or you provide a callback method that provides the list. Are you asking how to set the default entry in the list?
Tue Mar 27, 2018 1:07 pm
vtmikel offline
Example:
User visits the MenuItem UI for the first time, A Menu control is in the UI containing a list of devices. Default selection is hard coded into the MenuItems.xml.
User changes the list of selected devices in the control, saves, and the plugin saves the list of selected items to the pluginPrefs, as you suggested.
When the user goes back into the dialog, I provide the list of devices as I did on the initial load, but I need to select items based on the previous save, and not the defaults. <--- How do I do this last part?
Tue Mar 27, 2018 1:12 pm
Colorado4Wheeler offline
It's an unfortunate issue in the menu based config UI, if I really need to do that then I simply have a button a the top to refresh or I make the entire form invisible until they select an option, in which case that option has a callback that populates the fields. Now if you do this in the main plugin config then it'll pull from the dictionary of config prefs that is saved each time, but a custom menu based UI this is the only way I've found to make this happen.
Tue Mar 27, 2018 1:18 pm
vtmikel offline
Okay, thanks. I'm glad I'm not going crazy. I'll head back to using the Config dialog.
Tue Mar 27, 2018 1:23 pm
vtmikel wrote:
Example:
I'm still not sure I get the UI. Is this a single selection menu popup (type="menu")? Or a multi-select list (type="list")? I'm confused because you used the plural "select items", which implies a list.
Are you trying to do something like the "Manage Devices" in the LIFX Bridge plugin menu?
Tue Mar 27, 2018 1:29 pm
vtmikel offline
FlyingDiver wrote:
vtmikel wrote:
Example:
You're right, I said "menu" when I meant "list" for the example I gave, but I have the same problem for both. In both cases, setting the selected items in the UI based on past saves is where I'm stuck.
Tue Mar 27, 2018 1:43 pm
See this thread: viewtopic.php?f=108&t=12530&p=84214&hilit=dynamic+list+defaultValue#p84214
Basically, you need:
   def getMenuActionConfigUiValues(self, menuId):
      valuesDict = indigo.Dict()
      errorMsgDict = indigo.Dict()
      if menuId == "yourMenuItemId":
         valuesDict["someFieldId"] = someDefaultValue
      return (valuesDict, errorMsgDict)
That should fill in the "defaultValue=" data for a specific menu field, which you can do from your saved data.
Tue Mar 27, 2018 1:44 pm
There's a standard Indigo method for this.
        # Grab the setting values for the Subscribe to Changes tool
        if menuId == 'subscribeToChanges':
            changes_dict = indigo.Dict()
            changes_dict['enableSubscribeToChanges'] = self.pluginPrefs.get('enableSubscribeToChanges', False)
            changes_dict['subscribedDevices'] = self.pluginPrefs.get('subscribedDevices', '')
            return changes_dict
            return indigo.Dict()
it's called whenever a menu config UI is opened. I filter by the menu id. It works great.
    <MenuItem id="subscribeToChanges">
        <Name>Subscribe to Changes...</Name>
        <CallbackMethod>subscribedToChanges</CallbackMethod>
            <ConfigUI>
                <Field id="subscribeToChangesLabel" type="Label">
                    <Label>The Subscribe to Changes tool only subscribes to object updates (not objects created or deleted). If initially disabled, enabling subscriptions (or vice versa) will cause a plugin restart to effect the change. This in normal.</Label>
                </Field>
                <Field id="subscriptionChangeLabel" type="Label" fontColor="red">
                    <Label>It's recommended that you disable subscriptions when you're done using the tool in order to reduce traffic between the server and plugin.</Label>
                </Field>
                <Field id="enableSubscribeToChanges" type="checkbox">
                    <Label>Subscribe to Changes:</Label>
                </Field>
                <Field id="subscribedDevices" type="textfield">
                    <Label>Subscribed Devices:</Label>
                </Field>
                <Field id="subscribedDevicesLabel" type="Label" alignWithControl="true">
                    <Label>Enter a list of devices to subscribe to. The list should be Indigo device and/or variable IDs (separated by a comma). Subscriptions to other object types are not supported.</Label>
                </Field>
            </ConfigUI>
    </MenuItem>
    def subscribedToChanges(self, valuesDict, typeId):
        # If user changes subscription preference, set flag for plugin restart (see __init__)
        if self.pluginPrefs['enableSubscribeToChanges'] == valuesDict['enableSubscribeToChanges']:
            restart_required = False
            restart_required = True
        # Save preferences to plugin config for storage
        self.pluginPrefs['enableSubscribeToChanges'] = valuesDict['enableSubscribeToChanges']
        self.pluginPrefs['subscribedDevices']        = valuesDict['subscribedDevices']
        if restart_required:
            indigo.server.log(u"Preparing to restart plugin...")
            self.sleep(2)
            plugin = indigo.server.getPlugin("com.fogbert.indigoplugin.multitool")
            plugin.restart(waitUntilDone=False)
        return True
If the item is a list, I think you'll have to store the list as a string and convert it back to a list (if I'm understanding your scenario). Ignore the plugin restart bit--that was a special case because the tool is loading and unloading the subscribeToChanges() method which can only be done with a restart.
Tue Mar 27, 2018 3:16 pm
I'm so confused now... Are we talking about Plugin Prefs, a generic menu item that opens a config UI or are we talking about the Actions UI? Maybe better to ask, where is this config UI - in Devices.xml, Actions.xml, PluginConfig.xml or Menuitems.xml?
