Recovering from Lost Internet
PostPosted: Thu Mar 01, 2018 5:20 pm
by DaveL17
I'm getting results that I don't understand. Using this construct in terminal works as expected:
import os
from time import sleep
response = '1'
while response != 0:
    response = os.system("ping -c 1 google.com")
    sleep(2)
    print('.')
On the first trip through, the result with Internet is instant:
PING google.com (172.217.4.78): 56 data bytes
64 bytes from 172.217.4.78: icmp_seq=0 ttl=49 time=29.679 ms
--- google.com ping statistics ---
1 packets transmitted, 1 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 29.679/29.679/29.679/0.000 ms
Remove Internet, run, and then restore Internet:
ping: cannot resolve google.com: Unknown host
64 bytes from 172.217.4.78: icmp_seq=0 ttl=49 time=47.809 ms
round-trip min/avg/max/stddev = 47.809/47.809/47.809/0.000 ms
Same code, modified to run in a plugin:
except requests.exceptions.ConnectionError:
        self.sleep(2)
        indigo.server.log(u"{0}".format(response))
When Internet is removed, requests throws the exception and the while loop is called. However, when Internet is restored, the while loop is never broken, the ping response never reverts to 0 (zero) and instead just keeps reporting the non-zero number.
What am I missing?
Re: Recovering from Lost Internet
PostPosted: Thu Mar 01, 2018 6:10 pm
by Colorado4Wheeler
How about:
while int(response) != 0:
or
while unicode(response) != '0':
or
while not response == '0'
PostPosted: Thu Mar 01, 2018 7:30 pm
by FlyingDiver
Are you sure it's actually calling ping in that loop? Change it to "/sbin/ping" and see what happens. You might be getting an OS or shell error rather than a ping error.
PostPosted: Thu Mar 01, 2018 8:01 pm
by DaveL17
Thanks Joe - calling it from /sbin/ was the answer. Now it's working perfectly. Appreciate it.
I would've probably figured it out on my own if Matt made the font bigger. :D
