uiPath attribute for actions (just a reminder)
Mon Sep 04, 2017 10:24 am
Hey plugin developers - I just noticed that a lot of you (shamefully, including myself on some open source plugins) have failed to use this attribute on actions in your Actions.xml file. From the docs:
Added in API v1.4. You can specify where in the menu hierarchy your action will be placed. By default, Indigo will create a submenu at the bottom of the Actions list and put your actions there. If you specify “DeviceActions”, Indigo will create a submenu on the Device Actions menu and put your actions there. If you specify “NotificationActions”, Indigo will insert your action n the Notification Actions menu without a submenu (be sure to name your action appropriately so that it's clear what it does).
The reason for this is to make sure that actions that target a specific device, regardless of whether it's a built-in device or a plugin defined device, are available from the Device Actions action type menu. Ultimately we think users will be less confused about device-specific actions if they are there.
The same goes for notifications: if your plugin defines some kind of action whose usage is primarily a notification, then use that option so it shows up on the Notification Actions submenu. We may add more options in the future to help guide users to the right place when looking for the actions they want.
Just a reminder - the next time you do an update to your plugin, just take a quick look to see if using one of these attributes is appropriate.
Mon Sep 04, 2017 11:52 am
Re: uiPath attribute for actions (just a reminder)
I just tweaked a couple of the open source repos in our account (rachio and pushover) to move the associated actions.
