#!/bin/sh
# WeMo Control Script
# Original author: rich@netmagi.com
# Modified 7/13/2014 by Donald Burr
# email: <dburr@DonaldBurr.com>
# web: <http://DonaldBurr.com>
# Usage: wemo IP_ADDRESS[:PORT] ON/OFF/GETSTATE/GETSIGNALSTRENGTH/GETFRIENDLYNAME
IP=$1
CMD=`echo $2 | tr '[a-z]' '[A-Z]'`
if echo $1 | grep -q :; then
IP=`echo $1 | cut -d: -f1`
PORT=`echo $1 | cut -d: -f2`
else
PORTTEST=$(curl -m 1 --connect-timeout 1 -s $IP:49152 | grep "404")
if [ $? -ne 0 -o "$PORTTEST" = "" ]; then
PORT=49153
else
PORT=49152
fi
fi
if [ "$1" = "" ]; then
echo "Usage: `basename $0` IP_ADDRESS[:PORT] ON/OFF/GETSTATE/GETSIGNALSTRENGTH/GETFRIENDLYNAME"
else
if [ "$CMD" = "GETSTATE" ]; then
STATE=`curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:GetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 |
grep "<BinaryState" | cut -d">" -f2 | cut -d "<" -f1 | sed 's/0/OFF/g' | sed 's/1/ON/g'`
echo $STATE
if [ "$STATE" = "OFF" ]; then
exit 0
elif [ "$STATE" = "ON" ]; then
exit 1
else
exit 2
fi
elif [ "$CMD" = "ON" ]; then
curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>1</BinaryState></u:SetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 |
elif [ "$CMD" = "OFF" ]; then
curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#SetBinaryState\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetBinaryState xmlns:u="urn:Belkin:service:basicevent:1"><BinaryState>0</BinaryState></u:SetBinaryState></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 |
elif [ "$CMD" = "GETSIGNALSTRENGTH" ]; then
curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetSignalStrength\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetSignalStrength xmlns:u="urn:Belkin:service:basicevent:1"><GetSignalStrength>0</GetSignalStrength></u:GetSignalStrength></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 |
grep "<SignalStrength" | cut -d">" -f2 | cut -d "<" -f1
elif [ "$CMD" = "GETFRIENDLYNAME" ]; then
curl -0 -A '' -X POST -H 'Accept: ' -H 'Content-type: text/xml; charset="utf-8"' -H "SOAPACTION: \"urn:Belkin:service:basicevent:1#GetFriendlyName\"" --data '<?xml version="1.0" encoding="utf-8"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetFriendlyName xmlns:u="urn:Belkin:service:basicevent:1"><FriendlyName></FriendlyName></u:GetFriendlyName></s:Body></s:Envelope>' -s http://$IP:$PORT/upnp/control/basicevent1 |
grep "<FriendlyName" | cut -d">" -f2 | cut -d "<" -f1
else
echo "COMMAND NOT RECOGNIZED"
echo ""
echo ""
fi
fi
