[ANSWERED]: update Address/description fields in devices
Wed Jul 30, 2014 11:21 am
Creation of the devices works fine.
                  indigo.device.create(
                     protocol=indigo.kProtocol.Plugin,
                     address=theMAC,
                     name="MAC-"+theMAC,
                     description="",
                     pluginId="com.karlwachs.fingscan",
                     deviceTypeId="IP-Device",
                     folder=self.deviceFolderID
can I LATER update the address or description fields?
tried
               localPropsCopy = dev.pluginProps
               localPropsCopy.update({"description":"newTEXT"})
               dev.replacePluginPropsOnServer(localPropsCopy)
and update State.. does not work.
any advice?
Wed Jul 30, 2014 1:09 pm
Re: update Address/notes/description fields in devices
Hey Karl - check out the WUnderground plugin. I update the address field in that.
Wed Jul 30, 2014 1:51 pm
thanks
both statements work for the ADDRESS field but not for the DESCRIPTION field! ==> Matt , Jay is this correct?
               props = dev.pluginProps
               props["address"]="new text"   ### works
               props.update({"address":"new text"})   ### works
               props["description"]="new text"  ### does not work
               props.update({"description":"new text"})   ### does not  work
               dev.replacePluginPropsOnServer(props)
KArlk
Wed Jul 30, 2014 2:46 pm
This is a bit more confusing than I would like, but for description do:
dev.description = "new desc here"
dev.replaceOnServer()
Make sure dev is up-to-date (recently retrieved via indigo.devices[]) as the replace call above replaces the entire device with the local instance (python instance dev in this case).
Wed Jul 30, 2014 4:14 pm
Re: [ANSWERED]: update Address/description fields in devices
ok thx
Tue Jan 09, 2018 8:26 am
A follow on to this question, if I may?
If I use New... to create a new device which then opens Edit Device Settings... where I want to input an IP address in the IP Address field (in this example). I want to save this IP Address as the devices address. How do I do this in the method closedDeviceConfigUi ?
Updating the plugin props doesn't seem to work, possibly because the props are then getting nuked on the return from the method? I have tried adding address to the valuesDict but this just adds an unwanted entry into globalProps. :?
Tue Jan 09, 2018 10:00 am
here is how I do it:
0. in init:
self.updateRequired = ""
1. in validate device ui ..
valuesDict["updateDescription"] = "new info you wan to put into the notes field eg IP number"
self.updateRequired = dev.id
2. the in main loop check
if self.updateRequired  !="":
  dev= indigo.devices[self.updateRequired]
  dev.description =  dev.pluginProps["updateDescription"]
thats works, have not found a more elegant solution yet, if anyone has one, let me know
ps doing
  dev.description =  "new info"
in valdate device ui will be overwritten when indigo does the device save
Tue Jan 09, 2018 12:38 pm
Do you have "address" in your device's props? It should get mirrored to the dev.address property. In Indigo 7, I believe we started allowing arbitrary properties to get set in the validateDeviceConfigUi so I believe you can just add it there. If that doesn't work, you can always add a hidden field to your device's ConfigUI XML with the name "address" and populate that in validateDeviceConfigUi.
Tue Jan 09, 2018 1:12 pm
Thanks Jay :D
Setting a field with an id of address in the ConfigUI worked. The User sees a field label of IP Address and then when it is saved the device address is set.
Easy when you know how. :wink: Thanks again. :)
