Help with Basic Plugin Structure
Tue Aug 27, 2013 11:03 am
jd10884 offline
Good day,
This basic plugin structure below works except for the method "def start(self)". Can you tell me what I am doing wrong?
#! /usr/bin/env python
# -*- coding: utf-8 -*-
   def __init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs):
      indigo.PluginBase.__init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs)
      self.debug = pluginPrefs.get("showDebugInfo", True)
   def __del__(self):
   def start(self):
        indigo.server.log(u"want to use this to create a text file")
      pInterval = 10
      self.debugLog("Starting concurrent thread")
      self.debugLog("L25 testing of basic structure is set to update every %s %s" %(pInterval, 'seconds'))
         while True:
            self.sleep(int(pInterval))
            self.update()
      except self.StopThread:
         pass
   def update(self):
      self.debugLog('L45 testing basic plugin structure')
Thanks in advance
Jeff
Tue Aug 27, 2013 3:43 pm
Valdhor offline
Re: Help with Basic Plugin Structure
I can't imagine you want the superfluous "u" in the log statement.
Tue Aug 27, 2013 4:03 pm
nsheldon offline
Use "startup" instead of "start".
The "u" in front of the text of the log statement tells Python that the following string of text should be Unicode compatible text (as opposed to the default ASCII). It won't hurt anything by having it there and will improve compatibility with international character sets on non-Western systems.
