Trying to make an Home Assistant plugin
Tue Feb 05, 2019 3:06 am
steinis offline
Re: Trying to make an Home Assistant plugin
SST wrote:
Great work! Is it possible to expose home assistant`s filter attributes to the device state in Indigo? An example for me would be to integrate a climate device (mill) and have the temperature display instead of heat.
I have added the climate component to plugin version 1.04.
Give it a try and si if its fits your needs! For now only temperature as input an heat as mode is working.
Tue Feb 05, 2019 4:13 pm
SST offline
Nice! Thanks again:)
Sun Apr 14, 2019 11:32 am
jens offline
Have installed the program but where do I find this : HA access token ??
//Jens
Sun Apr 14, 2019 1:23 pm
roussell offline
You create/get the token from within Home Assistant. It’s under the accounts page I think
Terry
Mon Apr 15, 2019 11:21 am
jens offline
Thanks Terry,
Next problem get this in my log
Is this right for switch?
Skickat från min iPhone med Tapatalk Pro
Tue Apr 23, 2019 10:17 am
jens offline
Someone who has a solution to this error?
see above posts
//Jens
Tue Apr 23, 2019 10:32 am
A Python KeyError exception indicates the code is trying to get a key from a collection (dictionary for instance), in this case "state", that doesn't exist. I'm going to guess that the plugin developer assumed that "state" was always included in whatever JSON he's using, but clearly there are circumstances where it's not included (so he will need to trap and decide what to do). If the JSON displayed above the error is what he's using, then that seems to indicate that something that is being queried from the HA server doesn't exist. Are you sure that switch.4 is a valid value (not sure if that's related or not)?
Tue Apr 23, 2019 1:03 pm
jens offline
Not shore about that Jay,
This is the info from the switch
Tue Apr 23, 2019 4:55 pm
I know nothing about the plugin so I have no idea what to look for. Sorry...
Tue Apr 23, 2019 7:49 pm
roussell offline
Sorry I’ve missed these posts. I’m away from home at the moment but I’ll check my config when I return; I definitely don’t get those errors though. I’ll try to see if I can replicate what you’re doing and see what happens.
Terry
Tue Apr 23, 2019 11:24 pm
jens offline
Thanks Terry,
Don't know if it might be that I didn't create the right Token?
Which username you should write
//Jens
Wed Apr 24, 2019 1:12 am
steinis offline
Sorry for late replay, but I have been very busy.
I see that your are using the z-wave node number as name. Try to use the HA name instead, something like "switch.plugg".
Tip: You can find all your objects in HA under states page.
Thu Apr 25, 2019 8:29 am
jens offline
Dount work, what about the tolken
Thu Apr 25, 2019 11:57 am
Gusten offline
Hi this seems cool
Is this plug-in a possible way to get Google Assistant to work with indigo?
Thinking of using a pie with HA and trigger indigo devices and action group from HA using home assistant.
/Martin
Sun Apr 28, 2019 7:21 am
jens offline
Still not working, get this in Home Assistent logg
Could it be a problem med Tolken, no communication whith Indigo?
Any ideas?
//jens
