Controlling Indigo from Command Line (or .py files)
Wed Jun 01, 2016 12:15 pm
Re: Controlling Indigo from Command Line (or .py files)
I'm not sure what you find inelegant about using an Action Group to accomplish what you're doing. Other than the fact it appears you're doing most of your system control in Python scripts that are not, in fact, part of Indigo. They're just started up by Indigo when needed. If it was me, I'd be trying to figure out how to make the system more integrated with Indigo, not less. But that's just me. In any case, Jay already pointed out the solution to the executable path issue you were having.
Fri Jun 03, 2016 8:22 am
RedYuriPrime offline
OK, making some progress.
Having correctly con figured .bash_profile and .bashrc to set up the alias, I can no run in Terminal a .py file under the IPH. As an example:
Last login: Fri Jun 3 14:49:38 on ttys000
Geoffs-Mac-mini:~ geoff$ indigohost -x /Users/geoff/Documents/Indigo/ActivePython/TestEasyDAC.py
However, putting the same line:
into a .py file and then running this within Indigo gives the following error:-
Script Error Core.py: global name 'indigohost' is not defined
Core.py, line 68, at top level
NameError: global name 'indigohost' is not defined
So I must still be missing something.
Z-wave system with 80+ devices, Indigo7 on a dedicated MacMini
Controlling lighting, heating, hotwater, security; but still a lot to learn ... :shock:
Fri Jun 03, 2016 9:40 am
That's because the aliases you set up in your .bash_profile and .bashrc files are not available to scripts running from Indigo.
Just put the complete path name in your script as:
/Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoPluginHost.app/Contents/MacOS/indigohost -x /Users/geoff/Documents/Indigo/ActivePython/TestEasyDAC.py
Mon Jun 06, 2016 2:19 am
Thanks Joe. However have tried the format you and Jay provided, and unfortunately it doesn't work, giving:
Script Error Core.py: invalid syntax
Script Error around line 83 - "/Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost -x /Users/geoff/Documents/Indigo/ActivePython/TestEasyDAC.py"
Have resorted to the following; it does seem to work, although I do need to do further testing:
import subprocess
def rRun(module):
host ="/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost"
switch ="-x"
modulePath="/Users/geoff/Documents/Indigo/ActivePython/" + module
subprocess.Popen([host,switch,modulePath])
rRun("TestEasyDAC.py")
Will update in a few days to confirm if there are any unexpected side effects.
Regards,
Geoff
Fri Jun 17, 2016 2:41 am
OK, just an update to say that the above solution is stable and does the job. :D
