Python Script - Not authorized to send Apple events to Calen
Posted: Sat Jan 14, 2023 3:02 pm
I have a Python sciprt that calls an AppleScript to check for Holidays or Vacation. When I run it as attached or external it gives my an error: Not authorized to send Apple events to Calendar. The AppleScript runs fine from the Apple Script Editor. Is this a permission issue when Indigo runs scripts? Is there a fix?
Python Script:
AppleScript:
Python Script:
- Code: Select all
import time
import applescript
path_to_script_file = "/Users/Rick/Scripts/Calender Today.scpt"
my_ascript_from_file = applescript.AppleScript(path=path_to_script_file)
indigo.server.log("Checking if hoiday...")
reply = my_ascript_from_file.run()
if reply:
indigo.variable.updateValue("holiday", value="true")
indigo.server.log("hoiday set to true")
indigo.variable.updateValue("holiday", value="false")
indigo.server.log("hoiday set to false")
AppleScript:
- Code: Select all
set theDestCalendar to "House"
-- set startDate to date ((date string of (current date)) & " 00:00:00 am")
set startDate to (current date) -- (24 * 60 * 60)
set hours of startDate to 0
set minutes of startDate to 0
set seconds of startDate to 0
-- set endDate to (startDate + 2 * (24 * 60 * 60))
set endDate to startDate + (1 * days) - 1
tell application "Calendar"
set theEvents to events of calendar theDestCalendar whose start date is greater than or equal to startDate and start date is less than or equal to endDate
repeat with theItem in theEvents
set eventTitle to summary of theItem
-- say eventTitle
if eventTitle contains "Holiday" or eventTitle contains "Vacation" then
return true
end if
end repeat
return false
-- set eventTitle to summary of (item 1 of theEvents)
end tell
