- Code: Select all
Script Error schedule "sma webbox update" script error in file smapoll.py:
Script Error Strings must be encoded before hashing
smapoll.py, line 197, at top level
smapoll.py, line 74, in __init__
TypeError: Strings must be encoded before hashing
can anyone identify what str is the issue (assume the password) and point me to the correct syntax? thanks!!
script :
- Code: Select all
#! /usr/bin/env python
# -*- coding: utf-8 -*-
#!/usr/bin/env python
# version: 0.3
# date: 2012-11-30
# author: Joerg Raedler joerg@j-raedler.de
# updates: Dylan Tichenor for Indigo Automation system
# license: BSD
# purpose: make RPC to a Sunny WebBox, a monitoring system for solar plants
# http://www.sma.de/en/produkte/monitoring-systems/sunny-webbox.html
# Use the classes SunnyWebBoxHTTP or SunnyWebBoxUDPStream in your code
# or run this file as a script to test the classes. First parameter is
# the hostname or IP of the box. A password can be provided with an
# optional second parameter.
# Example: python SunnyWebBox.py 123.123.123.123 "foobar"
# Documentation on the RPC API can be found here:
# http://files.sma.de/dl/2585/SWebBoxRPC-BEN092713.pdf
import sys, json, hashlib
### I stick this at the top of all Indigo python scripts
import indigo
except:
print("This script must be run from Indigo to work properly")
raise
### No need for globals. They are generally bad and most often unnecessary as was the case here.
# handle python 2 and 3
if sys.version_info >= (3, 0):
py3 = True
def str2buf(s):
return bytes(s, 'latin1')
def buf2str(b):
return str(b, 'latin1')
py3 = False
def str2buf(s):
return bytes(s)
def buf2str(b):
return unicode(b, 'latin1')
class Counter:
"""generate increasing numbers with every call - just for convenience"""
def __init__(self, start=0):
self.i = start
def __call__(self):
i = self.i
self.i += 1
return i
class SunnyWebBoxBase(object):
"""Communication with a 'Sunny WebBox', a monitoring system for solar plants.
This is an abstract base class, please use SunnyWebBoxHTTP or
SunnyWebBoxUDPStream instead!
def __init__(self, host='192.168.0.98', password='xxxx'):
self.host = host
if password:
self.pwenc = hashlib.md5(password).hexdigest()
self.pwenc = ''
self.count = Counter(1)
self.openConnection()
def openConnection(self):
raise Exception('Abstract base class, use child class instead!')
def newRequest(self, name='GetPlantOverview', withPW=False, **params):
"""return a new rpc request structure (dictionary)"""
r = {'version': '1.0', 'proc': name, 'format': 'JSON'}
r['id'] = str(self.count())
if withPW:
r['passwd'] = self.pwenc
if params:
r['params'] = params
return r
def _rpc(self, *args):
def printOverview(self):
"""print a short overview of the plant data"""
for v in self.getPlantOverview():
print("%15s (%15s): %s %s" % (v['name'], v['meta'], v['value'], v['unit']))
# wrapper methods for the RPC functions
def getPlantOverview(self):
res = self._rpc(self.newRequest('GetPlantOverview'))
return res['overview']
def getDevices(self):
res = self._rpc(self.newRequest('GetDevices'))
return res['devices']
def getProcessDataChannels(self, deviceKey):
res = self._rpc(self.newRequest('GetProcessDataChannels', device=deviceKey))
return res[deviceKey]
def getProcessData(self, channels):
res = self._rpc(self.newRequest('GetProcessData', devices=channels))
# reorder data structure: {devKey: {dict of channels}, ...}
# return {l['key']: l['channels'] for l in res['devices']}
r = {}
for l in res['devices']:
r[l['key']] = l['channels']
return r
def getParameterChannels(self, deviceKey):
res = self._rpc(self.newRequest('GetParameterChannels', withPW=True, device=deviceKey))
def getParameter(self, channels):
res = self._rpc(self.newRequest('GetParameter', withPW=True, devices=channels))
r = {}
return r
def setParameter(self, *args):
raise Exception('Not yet implemented!')
class SunnyWebBoxHTTP(SunnyWebBoxBase):
"""Communication with a 'Sunny WebBox' via HTTP."""
if py3:
from http.client import HTTPConnection
from httplib import HTTPConnection
self.conn = HTTPConnection(self.host)
def _rpc(self, request):
"""send an rpc request as JSON object via http and read the result"""
js = json.dumps(request)
self.conn.request('POST', '/rpc', "RPC=%s" % js)
tmp = buf2str(self.conn.getresponse().read())
response = json.loads(tmp)
if response['id'] != request['id']:
raise Exception('RPC answer has wrong id!')
return response['result']
#class SunnyWebBoxUDPStream(SunnyWebBoxBase):
"""Communication with a 'Sunny WebBox' via UDP Stream."""
#def openConnection(self):
#from socket import socket, AF_INET, SOCK_DGRAM
#self.udpPort = 34268
#self.ssock = socket(AF_INET, SOCK_DGRAM)
#self.rsock = socket(AF_INET, SOCK_DGRAM)
#self.rsock.bind(("", self.udpPort))
#self.rsock.settimeout(100.0)
#def _rpc(self, request):
#"""send an rpc request as JSON object via UDP Stream and read the result"""
#js = ''.join(i+'\0' for i in json.dumps(request, separators=(',',':')))
#self.ssock.sendto(str2buf(js), (self.host, self.udpPort))
#while True:
#data, addr = self.rsock.recvfrom(10*1024)
#if addr[0] == self.host:
#break
#tmp = buf2str(data).replace('\0', '')
#response = json.loads(tmp)
#if response['id'] != request['id']:
#raise Exception('RPC answer has wrong id!')
#return response['result']
#if __name__ == '__main__':
#pw = ''
#ip = sys.argv[1]
#if len(sys.argv) > 2:
#pw = sys.argv[2]
ip = "192.168.0.98"
pw = "xxxx"
swb = SunnyWebBoxHTTP(ip, password=pw)
# swb = SunnyWebBoxUDPStream(ip, password=pw)
### Update Indigo variables with values from the overview
indigo.server.log("Starting updates to Indigo variables", type="SunnyWebBox Script")
for overview_dict in swb.getPlantOverview():
### The indigo.variables lines above did nothing, so I just removed them.
### Everything else needed to be moved. The variable v used below wasn't defined as
### you had it before because it wasn't within the scope of the for loop.
### Because Indigo variables are always stored as strings, I converted each
### value because I wanted to make sure that they were strings.
if overview_dict['meta'] == 'GriEgyTdy':
indigo.variable.updateValue(1822257245, str(overview_dict['value']))
if overview_dict['name'] == 'GriEgyTot':
indigo.variable.updateValue(1469286291, str(overview_dict['value']))
if overview_dict['name'] == 'GriPwr':
indigo.variable.updateValue(1958563501, str(overview_dict['value']))
if overview_dict['name'] == 'Mode':
indigo.variable.updateValue(789149473, str(overview_dict['value']))
# for d in swb.getDevices():
# devKey = d['key']
# print("\n #### Device %s (%s):" % (devKey, d['name']))
# print("\n ## Process data:")
# channels = swb.getProcessDataChannels(devKey)
# data = swb.getProcessData([{'key':devKey, 'channels':channels}])
# for c in data[devKey]:
# print(" %15s (%15s): %s %s" %
# (c['name'], c['meta'], c['value'], c['unit']))
# print("\n ## Parameters:")
# channels = swb.getParameterChannels(devKey)
# data = swb.getParameter([{'key':devKey, 'channels':channels}])
#indigo.server.log(unicode(swb))
