Python 3 error
Mon May 23, 2022 1:57 pm
SMUSEBY offline
Python 3 error
With the introduction of Indigo 2022.1, my key fobs have stopped working. The error message:
Script Error control page "0 Common" script error in file fDoorRFID OPEN.py:
Script Error No module named 'commands'
fDoorRFID OPEN.py, line 12, at top level
fDoorRFID OPEN.py, line 38, in <module>
ModuleNotFoundError: No module named 'commands'
The script referred to has been purged of tabs, and there is no mention of 'commands'., but for the record, "fDoorRFID OPEN.py) follows:
# opens fDoor if fDoor interlock variable is true; interlock true for 1 sec
import time
fDoorInterlock = indigo.variables[911502153].getValue(bool)
hseStatus = indigo.variables[1176596514].getValue(bool)
if hseStatus:
 indigo.variable.updateValue(911502153, value = "True") #set to true enabling operation of door latch
if fDoorInterlock:
 exec(open("/Library/Application Support/Perceptive Automation/Scripts/RFID-Access-Control.py").read())
 time.sleep(1)
 indigo.variable.updateValue(911502153, value = "False") #set to false
The script invoked, "RFID-Access-Control.py", has also been purged of tabs, and does mention "commands" on line 38:
This script requires the following Indigo variables:
lastTagRead, lastFrontDoorDeniedTime, lastFrontDoorEntryName,
lastFrontDoorEntryTag & lastFrontDoorEntryTime
In Indigo, you must create A Phidgets Standalone Controller device and
an Indigo Digital Output Device (on the 4 relay board) to control the
door solenoid.
# Enter the name of the Phidgets RFID Reader device created in Indigo...
RFIDReaderDevice = "z fDoorRFID_Reader"
# ... and the name of the device that controls the front door latch.
doorLatchDevice = "1 fHallFdoorLatch"
# Solenoid close duration in seconds
solenoidCloseTime = 3
# path to tag and history files
rfidFilesPath = "/Users/rss/Documents/phidgets/"
# Tag file name
rfidTagFile = "690-RFID-tags.txt"
# History file name
rfidHistFile = "RFID-history.txt"
# Set debug to True if necessary for testing
debug = True
########      Do not change anything below this line       ########
import indigo
import datetime
import commands
lastTagRead = indigo.devices[RFIDReaderDevice].states["currentTag"]
now = datetime.datetime.now()
lastTime = now.strftime("%B %d, %H:%M:%S")
indigo.variable.updateValue("lastTagRead", lastTagRead)
if debug: indigo.server.speak('red a tag')
grepReturn = (commands.getstatusoutput("/usr/bin/grep " + lastTagRead + " " + rfidFilesPath + rfidTagFile))
grepResult = grepReturn[0]
if grepResult != 0:
    historyLine = lastTagRead + ", DENIED 0000000000: N/A," + lastTime
    indigo.server.log(u"UNKNOWN TAG %s read. Access Denied." % (lastTagRead), type="RFID Access", isError=True)
    indigo.variable.updateValue("lastFrontDoorDeniedTime", lastTime)
    if debug: indigo.server.speak("Unknown tag, red")
    tagSearch = grepReturn[1]
    tagNum = tagSearch.split(':')[0]
    tagName = tagSearch.split(':')[1]
    tagDescr = tagSearch.split(':')[2]
    if debug: indigo.server.log(u"Tag Search: result code=%s" % (grepResult), type="RFID debug")
    indigo.server.log(u"Front door entry: name=%s, Descr=%s " % (tagName, tagDescr), type="RFID Access")
    if debug: indigo.server.speak("file red, and user name " + tagName + " found")
    indigo.device.turnOn(doorLatchDevice, duration=solenoidCloseTime)
    indigo.variable.updateValue("lastFrontDoorEntryName", tagName)
    indigo.variable.updateValue("lastFrontDoorEntryTag", tagDescr)
    indigo.variable.updateValue("lastFrontDoorEntryTime", lastTime)
    historyLine = lastTagRead + ", " + tagName + ": " + tagDescr + ", " + lastTime
historyResult = (commands.getstatusoutput("/bin/echo " + historyLine + " >>" + rfidFilesPath + rfidHistFile))
This script was written for me, and is way beyond my very limited python skillls.
I'd be very grateful for any suggestions.
Bob
Mon May 23, 2022 2:25 pm
Re: Python 3 error
Run this in Terminal:
pip3 install commands
Mon May 23, 2022 6:31 pm
SMUSEBY offline
Re: Python 3 error
In terminal, I upgraded to the current version of pip, and as instructed, I wrote "pip install commands", and the following message was returned:
Successfully installed pip-22.1.1
bSrvr1911:~ macMini1110$ pip3 install commands
ERROR: Could not find a version that satisfies the requirement commands (from versions: none)
ERROR: No matching distribution found for commands
I'm afraid I need more direction.
As always, thank you for your patience and help.
Bob
Mon May 23, 2022 6:34 pm
Re: Python 3 error
Do this and post the output.
pip show commands
Mon May 23, 2022 6:50 pm
SMUSEBY offline
Re: Python 3 error
clicking on "Select all" loads this support thread.
do I paste it somewhere, and then execute the 'pip show commands' in terminal? that doesn't make any sense.
Mon May 23, 2022 6:51 pm
Re: Python 3 error
You run it in Terminal, just like the previous command I posted.
Mon May 23, 2022 6:58 pm
SMUSEBY offline
Re: Python 3 error
Is this what you are asking for?
Last login: Mon May 23 17:55:32 on ttys000
bSrvr1911:~ macMini1110$ pip show commands
WARNING: Package(s) not found: commands
bSrvr1911:~ macMini1110$ Last login: Mon May 23 17:25:22 on ttys000
macMini1110 ttys000 Mon May 23 17:56 still logged in
macMini1110 ttys000 Mon May 23 17:55 - 17:55 (00:00)
macMini1110 ttys000 Mon May 23 17:45 - 17:45 (00:00)
macMini1110 ttys000 Mon May 23 17:25 - 17:25 (00:00)
wtmp begins Wed Dec 15 18:52
bSrvr1911:~ macMini1110$ bSrvr1911:~ macMini1110$ pip show commands
-bash: bSrvr1911:~: command not found
bSrvr1911:~ macMini1110$ WARNING: Package(s) not found: commands
-bash: syntax error near unexpected token `('
bSrvr1911:~ macMini1110$ bSrvr1911:~ macMini1110$ Successfully installed pip-22.1.1
bSrvr1911:~ macMini1110$ -bash: Successfully: command not found
-bash: -bash:: command not found
bSrvr1911:~ macMini1110$ bSrvr1911:~ macMini1110$ bSrvr1911:~ macMini1110$ pip3 install commands
bSrvr1911:~ macMini1110$ -bash: bSrvr1911:~: command not found
bSrvr1911:~ macMini1110$ bSrvr1911:~ macMini1110$ ERROR: Could not find a version that satisfies the requirement commands (from versions: none)
bSrvr1911:~ macMini1110$ -bash: syntax error near unexpected token `('
> bSrvr1911:~ macMini1110$ ERROR: No matching distribution found for commands
> -bash: ERROR:: command not found
Mon May 23, 2022 7:05 pm
Re: Python 3 error
What the heck is all that other junk you posted? The WARNING line should have been the end of it. I have no idea what all that other stuff is.
You said someone else wrote this script for you? You need to get them to fix it. There's a module called "commands" which the script uses, which was installed somewhere in your Python 2 install. But it's not a standard package and it doesn't exist for Python3. So you're stuck.
Mon May 23, 2022 7:28 pm
SMUSEBY offline
Re: Python 3 error
Even though it made no sense, I did what I understood your direction to be: in terminal, I typed 'pip show commands' and pressed enter; next I clicked on 'select all' next to code in this thread, pasted it in terminal, and pressed enter; finally, in terminal, cmd A, cmd C, and back to this thread, cmd V.
If you don't see an obvious solution, I'm afraid I'm screwed: it was written by berkinet, and he seems to have disappeared.
Tue May 24, 2022 4:00 am
Re: Python 3 error
I think there is/was a bug with Select All - I had a problem as well.
Anyway, all that aside, we can add looking at this script to the pile and see if anyone can update it for you.
Tue May 24, 2022 6:25 am
Re: Python 3 error
Found it. https://docs.python.org/2.7/library/com ... e-commands
That module was deprecated in Python 2.6. No wonder I've never seen it in 2.7 or later.
Change "commands" on lines 38, 47, and 73 to "subprocess", like:
door solenoid.
# Tag file name
# History file name
debug = True
import indigo
import datetime
import subprocess
grepReturn = (subprocess.getstatusoutput("/usr/bin/grep " + lastTagRead + " " + rfidFilesPath + rfidTagFile))
if grepResult != 0:
historyResult = (subprocess.getstatusoutput("/bin/echo " + historyLine + " >>" + rfidFilesPath + rfidHistFile))
Tue May 24, 2022 7:50 am
Re: Python 3 error
Wow. Nice job Joe.
+1
Tue May 24, 2022 10:44 am
SMUSEBY offline
Re: Python 3 error
I can get back into my house - how nice is that? I've been transformed from despair to elation.
It's not at all clear to me why I'm so fortunate to have your assistance.
Thank you!
Bob
