Where ist the error
Sat May 21, 2022 4:30 pm
Bildhauer offline
Where ist the error
Compiling th script:
from time import sleep
vSuchTyp ='Open/Close Valve'
ignoreFolderId = indigo.devices.folders.getId("unbenutzt")
ScanFolderId = indigo.devices.folders.getId("Aussenbereich")
for dev in indigo.devices.iter("indigo.zwave"): #stop all devices first
   if dev.enabled and dev.folderId != ignoreFolderId and dev.model == vSuchTyp :
    indigo.server.log("Stoppe Sprenger: "+dev.name)+" ("+str(dev.id)+") läuft!")
   indigo.device.turnOff(dev.Id)
    sleep(2)
I'm getting "Inconsistent use of tabs and space in indentation"
Where is my mistake or how can I correct it?
Best regards
Bildhauer!
Sat May 21, 2022 5:00 pm
Re: Where ist the error
The clue is in the error itself. In Python, I think it's best to use 4 spaces for each indention (there is debate about this, though). Both tabs and spaces are allowed; I always use spaces.
      sleep(2)
EDIT: Some of my indentions are assumptions; they might not be right for your script.
Sun May 22, 2022 4:43 am
Bildhauer offline
Thx, Compiler shows no error any more!
Sun May 22, 2022 3:54 pm
Bildhauer offline
Ilf I'm running the change script it shows:
Script Stoppe Sprenger: Großer Rasensprenger rechts - Relay Switch 2 (1372594569) läuft!
Script Error embedded script error:
Script Error 'RelayDevice' object has no attribute 'Id'
embedded script, line 8, at top level
AttributeError: 'RelayDevice' object has no attribute 'Id'
Any idea what the issue can be?
Best regards
Bildhauer
Sun May 22, 2022 3:56 pm
FlyingDiver online
That needs to be "dev.id". Python is case sensitive.
Sun May 22, 2022 4:00 pm
Bildhauer offline
Thx!, sometimes it's so easy!!
8)
