conditional loop
Sun Apr 03, 2022 7:26 pm
domlazar offline
conditional loop
I was using AppleScript and migrated to Python, I’m not very good for now and need some help
I need to create a conditional loop, turning ON/OFF output device until to reach specific condition, (input value). I was considering python script to do so. My problem is the loop starts on continuous process and never stops. The system does note recognize the condition to stop.
Thank with your help, here is where I am with Python:
venmarstatus=indigo.variable.updateValue(95594510, value='activation')
while venmarstatus<>"min échange":
    indigo.iodevice.setBinaryOutput(480710969, 0,True)
    indigo.iodevice.setBinaryOutput(480710969, 0,False)
    if indigo.devices[637045073].binaryInputs[0]==1:
        venmarstatus=indigo.variable.updateValue(95594510, value='min échange')
        break
Mac OS Montery 12.2.1 macmini
Indigo Pro 2021.2
Powerlinc 2413U
Mon Apr 04, 2022 5:08 pm
anyone offline
Re: conditional loop
In your original code:
vernmarstatus is set to None because unfortunately the function you used just sets the value.
vernmarstatus = indigo.variables[95594510].value
Would set vernmarstatus to the value of the indigo variable but you really don't need to use that because you know the value, you just set it.
FYI: Both <> and != are the same but use != because it works with both Python2 & 3
This might work...or get you closer to what you are trying to do.
# update value of variable to 'activation'
# loop FOREVER or until the break is called
while True:
   # Turn the Binary Output ON
   # Turn the Binary Output OFF
   # if some devices Binary input is equal to 1
      # update value of variable to min échange
      # exit loop
      break
Mon Apr 11, 2022 9:18 pm
domlazar offline
With the script below I have a constant loop, the server does not recognize the "binaryInputs[0]==1". Any idea how to stop it?
while True:
indigo.iodevice.setBinaryOutput(1812773431, 0,True)
indigo.iodevice.setBinaryOutput(1812773431, 0,False)
indigo.device.statusRequest(1812773431)
from time import sleep
if indigo.devices[1812773431].binaryInputs[0]==1:
break
Indigo Pro 2021.2
Powerlinc 2413U
Tue Apr 12, 2022 5:47 am
while True:
break
Please use CODE tags when posting code. ;)
I think the problem is you're not actually doing a sleep(), so the input never has a chance to change.
This might work.
while True:
    sleep(1)
    if indigo.devices[1812773431].binaryInputs[0] == 1:
        break
Tue Apr 12, 2022 8:25 am
Scripts should use:
self.sleep(1)
