Comparing 2 dates
Sun Aug 08, 2021 4:48 am
Bildhauer offline
Comparing 2 dates
Hello all,
for the logic of a script managing my irrigation system I would like to do the following:
    1. Each time the irrigation takes plays save the date in a variable
    2. take the timestamp as a date of today.
    3. tell me the amount of days between today and the lasst irrigation
To be honest: I was not able to write this simple script!
Best regards
Bildhauer
Thu Aug 12, 2021 8:17 am
ryanbuckner offline
Re: Comparing 2 dates
Bildhauer wrote:
Hello all,
Best regards
Bildhauer
As an alternative to storing all these variables and writing a script, you could consider using the Timers and Pesters https://wiki.indigodomo.com/doku.php?id=indigo_7_documentation:plugins:timersandpesters plugin to:
    1. Start a timer when the first irrigation occurs
    2. Reset the timer on each irrigation
    3. Show your timer value on a control page, or Alexa, or however you want to find out the info
Thu Aug 12, 2021 1:54 pm
Bildhauer offline
Thx, but I need a solution as described.
But thank you for help!
Best regards
Bildhauer1963
Thu Aug 12, 2021 3:35 pm
berkinet offline
Thu Aug 12, 2021 5:05 pm
import datetime as dt
#  date_1 = indigo.variables[12345].value()  # This is how you get the value of an Indigo variable
date_1 = "2021-08-09 12:34:30.12345"  # Indigo variables are strings, so they must be converted
date_2 = "2021-08-12 23:45:00.54321"
d1 = dt.datetime.strptime(date_1, "%Y-%m-%d %H:%M:%S.%f")  # This is how you convert the strings to date objects
d2 = dt.datetime.strptime(date_2, "%Y-%m-%d %H:%M:%S.%f")
diff = d2 - d1
indigo.server.log(str(diff.days))
If you want fractional days, the last line would require a bit more effort (but not a lot more effort).
