I recently updated to an M1 Mac Mini as well and migrated my existing setup over to it. Everything went swimmingly except that I can't seem to get num2words and PIL/Pillow installed on the Python instance there. I'm -> <- this close to reformatting the whole thing and/or returning the Mini as I really use both these packages.
I've poured through the forums here (especially Jay's pinned post) and googled the heck out of this but could really use some help if anyone has it. I'm not sure if this is specific to my M1 Mac or not even related but could use some advice.
- Code: Select all
tornado@macmini:~/Library/Python/2.7/lib/python/site-packages% which python
/usr/bin/python
tornado@macmini:~/Library/Python/2.7/lib/python/site-packages% which pip
/usr/local/bin/pip
tornado@macmini:~/Library/Python/2.7/lib/python/site-packages% pip -V
File "/usr/local/bin/pip", line 11, in <module>
load_entry_point('pip==21.1.1', 'console_scripts', 'pip')()
File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources/__init__.py", line 489, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources/__init__.py", line 2843, in load_entry_point
return ep.load()
File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources/__init__.py", line 2434, in load
return self.resolve()
File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources/__init__.py", line 2440, in resolve
module = __import__(self.module_name, fromlist=['__name__'], level=0)
File "/Library/Python/2.7/site-packages/pip-21.1.1-py2.7.egg/pip/_internal/cli/main.py", line 58
sys.stderr.write(f"ERROR: {exc}")
SyntaxError: invalid syntax
Trying to install num2words gives me a similar error:
- Code: Select all
tornado@macmini:~% sudo pip install num2words
Password:
return ep.load()
PIL's is the same.
Any help greatly appreciated.
Joe
