Execute actionGroup with delay
Mon Dec 07, 2020 3:13 am
pauerbuk offline
Hi, i'm very new to pyton, sorry:
Wanting to upgrade to version 7.4, i am trying to convert all Applescripts to pythons.
In Applescript it was possible to execute a delayed ActionGroup; in pyton, this command:
indigo.actionGroup.execute(343928657, delay=6300)
returns: "Pyton argument types in".
Why? how can I do?
Thanks in advance.
Mac mini 2,4 Ghz Intel Core 2 Duo - El Captain 10.11.1
Mon Dec 07, 2020 5:37 am
Re: Execute actionGroup with delay
As far as I know, this is still the recommended method to script an action group delay:
import time
time.sleep(NUMBEROFSECONDSHERE)
indigo.actionGroup.execute(123)
https://forums.indigodomo.com/viewtopic.php?f=107&t=16487#p119910
Mon Dec 07, 2020 8:33 am
pauerbuk offline
It is a crazy thing :oops: :oops: :oops:
thanks anyway! This delay the script?
Mon Dec 07, 2020 9:07 am
When executed, the script will pause for 'NUMBEROFSECONDSHERE' seconds before continuing.
import time
# do first stuff
indigo.activePlugin.sleep(60)
# do second stuff
When executed, the 'first stuff' will happen right away. Then the script will pause for 60 seconds (during which nothing will happen), and then the script will execute the action group and continue on with the 'second stuff'.
Mon Dec 07, 2020 10:14 am
Note that you don't want to do that in an embedded script since those have to execute/complete in 10 seconds.
Tue Dec 08, 2020 3:35 am
pauerbuk offline
I think I'll keep forever version 7.3 with Applescript that works so well ...
Tue Dec 08, 2020 3:50 pm
I was thinking about this as a diversion from working on something else and I think the easiest way to send a (non-blocking) delayed actiongroup.execute() command is to run it in its own thread. I tested this approach with a 5 second delay and it works well. Presumably it will work just as well with your 6300 second delay, but I didn't test that. :D
import threading
import time
def actionGroupDelay(action_id, seconds):
    indigo.activePlugin.sleep(seconds)
    indigo.actionGroup.execute(action_id)
indigo.server.log(u"Do some stuff")
# =========================  Execute Delayed Action  ==========================
t = threading.Thread(target=actionGroupDelay, args=[1450401770, 5])  # Replace with your action id, time in seconds
t.start()
indigo.server.log(u"Do some more stuff")
When I run this code, "Do some more stuff" appears in the log instantly, and the action group is executed after 5 seconds. There are other ways to do this, but I think this is probably the most straightforward.
Wed Dec 09, 2020 11:38 am
pauerbuk offline
Thank you very much Dave! I will try as soon as possible, and I'll let you know the result.
Wed Dec 09, 2020 11:58 am
The easier solution, IMO, is to just use the script he posted first as an external script if for no other reason that it's more straight-forward.
The threading option is interesting - just not sure what side effects it might have when used as an embedded script on other scripts scheduled by Indigo. It might work fine but we've never really tested it.
Wed Dec 09, 2020 7:06 pm
I did some tests with Jon (Autolog) where we both ran the threaded version from within an embedded script (I went as high as 60 seconds on the delay) and both Indigo and the delayed execute never missed a beat. That said, YMMV and I would strongly encourage you to take Jay's advice and run the code in a linked script.
Thu Dec 10, 2020 3:54 am
pauerbuk offline
Hi Dave, you are great!
I tried your code with a 60 second delay, (in an embedded script ): the script doesn't time out and executes correctly.
The server is responsive, so you maybe gave me the solution.
However I also tried assigning a variable in Indigo from the calling script, and then using it in the external script with delay, but if this method works it's better !!!
Thank you again - bye
Thu Dec 10, 2020 5:58 am
Glad we were able to find something that works for you. I would still encourage you to save the script to disk and run it as a linked script as there's not really anything but upside to doing it that way. I run all of my scripts from files and it works great. You can keep all of your scripts in one place, and use a plain text editor to read and write them.
Good luck!
Thu Dec 10, 2020 10:40 am
I took the liberty of making a small tweak to Dave's post by changing the time.sleep() call to instead be indigo.activePlugin.sleep(). The advantage of the latter (which can also just be called via self.sleep() from plugins) is that the Indigo Server can more politely (not force kill) the python process using Indigo's special version of the sleep method. For delays of just a second or two it that doesn't really matter, but if one is doing longer delays the modified sleep() will listen for the process stop messages coming from the Indigo Server whereas time.sleep() just blocks.
Thu Dec 10, 2020 11:05 am
That doesn't seem fair. I don't get the chance to change any of your posts. :D
I'm crafting a simple shim for this and will change the sleep call there as well.
(Thanks Matt!)
