Incrementing a variable
Tue Nov 24, 2020 10:00 pm
SMUSEBY offline
I would like to count how many days the house is occupied, depending on season.
I am unable to count winter occupancy below. - my script is attempting to update the winterCount variable with its revised value.
Suggestions?
hseStatus = indigo.variables[1568794432].value
season = indigo.variables[325456157].value
winterCount = indigo.variables[255681698].getValue(int)
if hseStatus == "Occupied":
   if season == "winter":
      winterCount += 1
      indigo.variable.updateValue(255681698, winterCount)
Wed Nov 25, 2020 7:20 am
Re: Incrementing a variable
Without knowing the error that you're getting, I can only presume it's because your last line is trying to update the variable with an integer. Indigo variables can only be strings, so try updating your last line to:
indigo.variable.updateValue(255681698, str(winterCount))
Wed Nov 25, 2020 12:54 pm
SMUSEBY offline
There wasn't any error message - you guessed right, it's simply not updating.
Thanks.
Wed Nov 25, 2020 3:55 pm
Did changing the last line to my suggestion solve the problem for you or is it still broken?
Wed Nov 25, 2020 8:07 pm
SMUSEBY offline
It did. Very easy change.
Thank you.
Wed Nov 25, 2020 9:20 pm
Good deal.
