Python, (Indigo) and Umlaute
Sat Mar 28, 2020 9:43 am
davinci offline
Automower= indigo.variables["Automower"].value
if Automower == "Mähen" :
    result = true
    result = false
The variable is "Mähen".
Why is the result false?
I tried adding this at the top of the python file but still...
# -*- coding: utf-8 -*-
It works with this:
if Automower == u"Mähen" :
Is the problem on Indigo or on Python?
Sat Mar 28, 2020 11:17 am
Re: Python, (Indigo) and Umlaute
In Python 2.X you need to explicitly identify a string as unicode, so your change was correct:
    result = true
    result = false
Sat Mar 28, 2020 1:57 pm
davinci offline
Good to know, but weird...
Thanks.
Sat Mar 28, 2020 2:08 pm
Why do you think it's weird? The original definition of the string type in Python was ASCII encoding. Unicode was added as a new type. Then in Python 3, the default for all strings was made Unicode, and if you wanted an "old style" string you needed to use the b"" notation.
