Calling script in another file
Tue Feb 25, 2020 1:54 pm
trevorsmith offline
I created a file call abc.py in my docs directory and am trying to call a function in a separate file called def.py , also in the same location.
abc.py contains
import def
blah
myfunc(1)
blah
def.py contains
def myfunc(argumentname):
blah
blah
blah
abc.py is run by a trigger in Indigo, but python fails to find def.py
What am I doing wrong? If I put def.py into Python's site-packages folder then its found but that seems a silly place to put my scripts.
Sorry for the idiot question
Tue Feb 25, 2020 2:08 pm
Re: Calling script in another file
I assume you actually tried that without the comment character and with the correct function name?
abc.py:
from def import settrv
blah
settrv(1)
blah
def.py:
def settrv(argumentname):
    blah
    blah
    blah
Tue Feb 25, 2020 2:31 pm
trevorsmith offline
sorry yes, that was a typo
Tue Feb 25, 2020 2:36 pm
Rename def.py to __init__.py and put it inside a folder named "def":
abc.py
def
    __init__.py
Then try it.
How are you testing this? In a terminal session with those files in the current working directory?
Tue Feb 25, 2020 2:38 pm
Actually, before you do that, try:
import def
blah
def.settrv(1)
blah
Tue Feb 25, 2020 2:46 pm
trevorsmith offline
I have a trigger that invokes the script in abc.py. abc.py gets called fine and runs otherwise as it should. Its just the calling of the function in def.py that's going wrong.
the log file contains
Script Error abc.py: No module named myfunc
Tue Feb 25, 2020 2:58 pm
Oh. In that case you need to put the included file (def.py) in a place that Indigo puts in the search path. There's some threads about that in one of the forums. Read this one:
viewtopic.php?f=75&t=23450
