Efficiently trigger huge script when changes happen
Sat Feb 08, 2020 12:56 pm
davinci offline
I have over 1000 lines of code that I need to run because I need some variables calculated soon after they change.
The problem is that if I run it every second, IndigoServer goes up to 70% CPU load. 5 seconds brings it below 10%.
How can I trigger the scripts every second but only if there are changes to the variables or devices?
Should I check for the SQLite Database (from SQL Logger) or is there another way?
Sat Feb 08, 2020 1:51 pm
Re: Efficiently trigger huge script when changes happen
Convert it to a plugin.
How many variables are you needing to monitor?
Sun Feb 09, 2020 1:53 am
davinci offline
Should be a few hundred variables and devices.
I found a way with the plugin Group Change Listener.
I change one variable (which I don't select in the plugin) :mrgreen: with a timestamp in milliseconds.
import time
current_milli_time = int(round(time.time() * 1000))
indigo.variable.updateValue("UpdateIndigoRequested", str(current_milli_time))
Not sure how critical it is since it could trigger 50 times at once...
For now I just delay the execution by a second and remove deleted triggers. This could be critical if I get too many changes within seconds so it never executes...
