Requests timeout
Mon Nov 11, 2019 4:50 pm
Requests timeout
I'm getting nearer/further with the Tesla timeout.
head = {'Authorisation': u'Bearer abcdefghihjklmnopqrstuvwyx'}
req = Request("https://owner-api.teslamotors.com/api/1/vehicles/123456789/data_request/vehicle_config", headers=head)
resp = urlopen(req)
Those three lines, with an appropriate auth code, should retrieve a JSON of vehicle data.
Instead they're instantly (<1 second) returning HTTPError 408: Request Timeout
I've added timeout=30 but it still fails in <1 second.
resp = urlopen(req,timeout=30)
If I modify the auth to an invalid one, it returns 401 Unauthorised, so I know the auth is ok.
Any suggestions?
Peter
Mon Nov 11, 2019 4:58 pm
Re: Requests timeout
Ah, if i change it to http, not https, the timeout parameter starts to work - but it then errors with URLError not HTTPError.
Mon Nov 11, 2019 5:29 pm
The requests library (which is included with Indigo) may give you better information.
Mon Nov 11, 2019 5:31 pm
Ah, didn’t realise requests and Urllib2.Request were different.
Mon Nov 11, 2019 5:36 pm
Mon Nov 11, 2019 5:55 pm
:evil: :evil: :@~£&*/ :x *-+*/# :x #/,./! :oops: :oops: :oops:
Requests says "Vehicle not available"
So I POST the "wake_up" command.
Then suddenly Requests says "200 Ok"!
GRRR!
Tue Nov 12, 2019 10:00 am
I read somewhere that there was at least consideration of making the requests module a standard part of Python. I wholeheartedly agree that it should happen. I think the rationale has been that keeping it out of the Python release cycle would allow for more frequent updates. But I think it's become fairly stable recently, and with the new commitment by the Python community to do yearly releases, that fear is significantly lessened.
Tue Nov 12, 2019 10:41 am
If I was writing a plugin from scratch, I’d automatically go for requests because I’ve seen you and Joe comment on it so much.
Unfortunately Tesla was taken over from someone else, pre-written with urllib2.request, so I foolishly/blinkeredly thought it was the same thing.
