Comparing outside temps and updating variables in Python
Tue Oct 29, 2019 2:48 pm
Sofabutt offline
I am in the process of updating my Indigo serv er scripts to Python and have been working on this particular script all day.
I want the script to update the yearlyHighTemp and yearlyLowTemp as the temperature outsides rises above or below the current hig and low. This is what I have so far:
nowTemp = indigo.variables[1403030637].value
yearHigh = indigo.variables[762466133].value
yearLow = indigo.variables[128906629].value
if nowTemp > yearHigh
    indigo.variable.updateValue(762466133, value=float(nowTemp.value))
I get the following error when I try it:
Script Error embedded script: invalid syntax
Script Error around line 5 - "if nowTemp > yearHigh"
Can someone please help?
Thanks in advance.
Tue Oct 29, 2019 2:57 pm
Re: Comparing outside temps and updating variables in Python
.value returns a string. You need to use .getValue(float).
Also, your if line needs a ":" at the end. That's what's actually causing the syntax error.
Tue Oct 29, 2019 2:59 pm
nowTemp = indigo.variables[1403030637].getValue(float)
yearHigh = indigo.variables[762466133].getValue(float)
yearLow = indigo.variables[128906629].getValue(float)
if nowTemp > yearHigh:
    indigo.variable.updateValue(762466133, value=nowTemp)
Tue Oct 29, 2019 3:37 pm
Sofabutt offline
Thanks for your help. That fix eliminated an error that kept popping up every few minutes as the temp outsides soars above 28 degrees F.
