HTTP POST a JSON-formatted
Sun Oct 06, 2019 1:34 pm
RAID5 offline
Hi
I'm a beginner to Python and need some assistance.
I have used a plugin for a long time named Beacon and now it has stopped working because of my App on my phone suddenly stopped working.
The reason only wanted to use this app is that it post from the provider servers and I could open IPs from the provider and not the whole internet.
Other apps post from the phone and I don't want that.
I now have a temporary solution but need to create a Python script to post to the plugin while I create a new solution.
I have following command in my app when posting and need to replicate it in Python code in indigo instead.
http://server.nu:123/?sender=my.name@gm ... vent=enter
More information about the Beacon plugin here:
http://www.indigodomo.com/pluginstore/121/
https://github.com/IndigoDomotics/Beacon/
RAID5 "A happy Swede addicted to automation"
Sun Oct 06, 2019 3:37 pm
Re: HTTP POST a JSON-formatted
Check out https://requests.kennethreitz.org/en/master/
import requests
req = requests.get('http://server.nu:123/?sender=my.name@gmail.com&location=home&event=enter')
Sun Oct 06, 2019 9:56 pm
RAID5 offline
Hi
Thanks for your fast reply
I tried your code with a small change, I need to make a post instead. So I changed to post in the command.
But it didn't work. I got following error message
Beacon Error Exception: cannot concatenate 'str' and 'NoneType' objects
import requests
req = requests.post('http://server.nu:123/?sender=my.name@gmail.com&location=home&event=enter')
Mon Oct 07, 2019 12:11 am
Is that your only code in this script?
Because there’s no concatenation taking place in that code to cause that error, that I can see?
Mon Oct 07, 2019 6:14 am
A POST is slightly different.
requests.post('http://server.nu:123/', data = {'sender':'my.name@gmail.com', 'location':'home', 'event':'enter'})
Mon Oct 07, 2019 11:12 am
RAID5 offline
Now i got this error instead.
Beacon Error Didn't recognise received data. (User-agent: python-requests/2.10.0, Content-type: application/x-www-form-urlencoded)
Mon Oct 07, 2019 11:17 am
Do you have an example of a successful call to that URL from a command line using curl? Or anything else? That's correct for the data you gave me, but I can't be sure that was complete.
Mon Oct 07, 2019 11:28 am
RAID5 offline
Here is a snapshot from a similar application called Locative
Sending a test from this App results in this in the log in Indgo
Beacon Enter location notification received from sender/location ff0c7684-0aa0-4cea-a7b0-01cd2c9c0abf@@test
I think it's using JSON to POST but I'm not sure.
Mon Oct 07, 2019 11:56 am
There was a typo in the code I posted. Try using this fixed version:
Mon Oct 07, 2019 12:41 pm
RAID5 offline
If you meant the typo next to event, I spotted that and corrected it before.
Mon Oct 07, 2019 12:48 pm
Well, that's how you do it in Python. Once you figure out what the correct parameters are.
If you think it's actually expecting a JSON payload, you might want this:
requests.post('http://server.nu:123/', json={'sender':'my.name@gmail.com', 'location':'home', 'event':'enter'})
Mon Oct 07, 2019 2:19 pm
RAID5 offline
YES you are the man!!!
I was close, so close, I have missed the forward slash after the port number.
Thanks alot!
