- Posted on
Sat Oct 05, 2019 7:05 am
Eagleye
offline
Thanks Dave, I really appreciate your help on this.
Given that the Multisensor picks up six different variables, including temperature. How does your script know to select temperature?
Can you please point me to the Device ID # is should be using to make this work, from the info below.
My external sensor shows the following
infoIndigo Z-Wave Version: 7.4.0
Node ID: 21
Model: Multi Sensor 6 (ZW100)
Model ID: 02020064
Manufacturer: Aeon Labs
Manufacturer ID: 0086
Protocol Version: 4.05
Application Version: 1.08
Model Definition Version: 4
Library Type: 3
Class Name: Multilevel Sensor (routing)
Class Hierarchy: 04 : 21 : 01
Command Class Base: 31
Command Versions: 20v1 80v1 84v2 85v1 86v1 30v1 70v1 31v5 72v1 73v1 71v1 59v1 7Av1 5Av1 5Ev1
Features: routing, battery, beaming, waking
Neighbors: 2, 3, 4, 7, 24, 25, 26, 27, 28, 29, 50, 67, 70, 71, 74
Associations: 1:[1]
Config Values: 64:1 2:0 3:240 4:5 5:1 101:240 102:0 103:0 40:0 111:900 112:1800 113:1800 252:0
and the internal sensor shows the following.
Node ID: 6
Model ID: 02020064
Library Type: 3
Neighbors: 2, 3, 7, 9, 11, 13, 14, 15, 17, 19, 24, 25, 26, 27, 28, 29, 30, 36, 39, 40, 44, 46, 50, 65, 66, 67, 71, 72, 74
Associations: 1:[1]
Config Values: 64:1 2:0 3:240 4:5 5:1 102:0 103:0 40:0 111:1800 112:1800 113:1800 252:0 101:240
