Python Quickie
Thu Aug 15, 2019 10:10 am
jltnol offline
Python Quickie
So I had this script originally and it worked just fine.
alarmPanel = 1145882715
alarmPanelState = indigo.devices[alarmPanel].states['panelReady']
day = indigo.variables[1864332157]
if alarmPanelState == "0":
      indigo.dimmer.setLedState(215921706, index = 4, value = False)
elif alarmPanelState == "1" and day.value == "true":
   indigo.actionGroup.execute(327874994), indigo.actionGroup.execute(1040855971)
elif alarmPanelState == "1" and day.value == "false":
   indigo.actionGroup.execute(327874994), indigo.actionGroup.execute(53352835)
So now I'm trying to amend it for something else, and tried this, but it doesn't work.
day = indigo.variables[507666416]
if day.value == "true"
   indigo.actionGroup.execute(1909876887)
elif day.value == "false"
   indigo.actionGroup.execute(1300897338)
I've been keeping copies of all the Python scripts that I've cobbled together, MAINLY with so much help from users here.... but don't see a version where I used the day variable like in the 2nd example, only used the day variable as in the 1st script. The error is on the first "if" line... but no doubt the "elif" line won't work either... (I am aware the "day" variables have different ID's, which isn't the problem...)
Any suggestions ?
Thu Aug 15, 2019 10:17 am
Re: Python Quickie
You're missing the colons at the end of the if/elif lines:
if day.value == "true":
elif day.value == "false":
Thu Aug 15, 2019 10:37 am
jltnol offline
Re: Python Quickie
Duh!
Thanks..
