Mute Mac Volume
Tue Jun 11, 2019 11:19 pm
koburg offline
Mute Mac Volume
I want to make a Schedule to turn the volume for the Mac running indigodomo down (MUTE) is there any way to do this ?
have tried searching the forum no luck so far.
Tue Jun 11, 2019 11:39 pm
koburg offline
Re: Mute Mac Volume
thanks but also want to know how to do it in python
because of what yourself mentioned.
Wed Nov 17, 2021 5:28 pm
wideglidejrp offline
Re: Mute Mac Volume
I have the same need. Anybody find a way to do this?
John R Patrick
Author of
Home Attitude
Thu Nov 18, 2021 8:04 am
McJohn offline
Re: Mute Mac Volume
You can do this with a simple external AppleScript (sorry):
tell application "Finder" to set volume 0
Or via a more complex way:
https://dev.to/kojikanao/control-mac-so ... python-h4g
BTW: we are using Airfoil and the Indigo Airfoil plugin to control all the speakers/volume through the whole house, works perfect.
John
Thu Nov 18, 2021 3:32 pm
Re: Mute Mac Volume
I don't see how Finder can change the Mac volume. Also, I don't want to use an AppleScript. The other solution you describe may be just what I have been looking for. What I am trying to do is mute my Mac from an action group. I tried to install osascript but it did not work. Also, does osascript support python?
John R Patrick
Author of
Home Attitude
Tue Nov 30, 2021 10:45 am
Re: Mute Mac Volume
There is no built-in way for Python to do this. osascript is also a command line utility that's installed with macOS, and that's probably the best bet. You can call it from python:
import os
os.system("/usr/bin/osascript -e 'tell application \"Finder\" to set volume 0'")
Sat Dec 04, 2021 2:11 pm
Re: Mute Mac Volume
This solution works perfectly in my Python script. The question I have is how does it work? I am not aware of any actions I can take with Finder to change system volume. Is it a hidden command?
John R Patrick
Author of
Home Attitude
Sat Dec 04, 2021 2:13 pm
Re: Mute Mac Volume
The Finder is just the app that's providing the interface for scripting for the sound system. AppleScript targets apps, so they had to put it somewhere. It does the same things as the volume control keys.
Also, there are menu bar controls for volume. What app is that?
Wed May 04, 2022 2:29 pm
rustyhodge offline
Re: Mute Mac Volume
All you actually need is:
import os
os.system("/usr/bin/osascript -e 'set volume 0'")
