Simple Rounding Question
Mon Jun 10, 2019 8:27 pm
jltnol offline
I'm keeping tabs on something that outputs in seconds... but there are thousands of them, so the number is meaningless. I'm trying to get the seconds converted to hours, which I've been able to do, but would like to keep the answer to 2 decimal places.
Here is my original code:
theDifa =str(float(theVar1.value) /3600) #seconds into hours
indigo.variable.updateValue(1924530586, ((theDifa)))
and this is what I get:
7.53694444444
and here's ONE of the things I've tried, but of course, it doesn't work:
answer = str(round(theDifa, 2))
indigo.variable.updateValue(1924530586, ((theDifaR1)))
So basically, I'm taking the value of theVar1, divide by 3600 (seconds in an hour), then truncate the answer to 2 decimal places, and then put it back into a Indigo Variable. Do I need to create a new variable to be the x,2 number, and then put that back into the Indigo Variable ?
Mon Jun 10, 2019 8:37 pm
Re: Simple Rounding Question
theDifa = "{:.2f}".format(theVar1.value /3600.0)
indigo.variable.updateValue(1924530586, theDifa)
Mon Jun 10, 2019 8:51 pm
jltnol offline
Hey Joe
Thanks for your help, the code passes the compiler, but I'm getting an error message:
Script Error                    embedded script: unsupported operand type(s) for /: 'unicode' and 'float'
     embedded script, line 14, at top level
TypeError: unsupported operand type(s) for /: 'unicode' and 'float'
I'm totally in the dark here as to what the error means, much less how to fix it.
Mon Jun 10, 2019 8:53 pm
I think this works:
theDifa = "{:.2f}".format(theVar1.floatValue /3600.0)
If not, this will:
theDifa = "{:.2f}".format(float(theVar1.value) /3600.0)
Mon Jun 10, 2019 8:54 pm
Means that theVar1.value was returning a unicode string, not a float. My bad.
Mon Jun 10, 2019 9:05 pm
jltnol offline
The 2nd one works perfectly
Thanks again for your help. :D
