Adding two variables together
Tue May 28, 2019 2:39 pm
mwoodage offline
Hello,
I've nearly managed to sort this out myself, but just need some help with the last bit! I'm writing a python script to add two variables together.
I'm trying to take a temperature reading from our hot tub, but the only place i can mount the probe gives a temperature reading that's 3 degrees lower than the actual temperature. So i've written the following which adds both variables together but it doesn't bring across the .68 (or what ever the figure after the decimal point is).
Can anyone help with how to transfer the .68 across?
hottubtemp = int(float(indigo.variables[394455824].value))
hottubtempset = int(float(indigo.variables[1175215717].value))
hottubtempact = hottubtemp + hottubtempset
indigo.variable.updateValue(1590980300, value=str(float(hottubtempact)))
Thanks in advance
Martin
Screenshot 2019-05-28 at 21.30.13.png (51.87 KiB) Viewed 1031 times
Tue May 28, 2019 4:16 pm
racarter offline
Re: Adding two variables together
Remove the ints. You’re converting the first two numbers to integers, which always rounds down. Since you’ll then be adding two floats you won’t need the float on the last line.
Wed May 29, 2019 6:18 am
mwoodage offline
That works! Thank you so much, its easy when you know how :lol:
Martin
Wed May 29, 2019 6:30 am
racarter offline
Happy to help :)
