Subtracting Time
Fri May 24, 2019 11:11 pm
jltnol offline
Subtracting Time
In an effort to keep track of how long the AC runs every day, I've been working on a script. When the unit comes on, a trigger entered the time into a variable. When the unit goes off, that time is entered into a second variable. And while I though I had this figured out, I quickly realized that just doing the math doesn't work, as when it comes on at 0758, and goes off at 0805, it hasn't been running for 47 minus, as the basic math would indicate.
I did a bunch of research online but sadly, can't quite figure out how to do time math. I've read up on datetime and timedelta, but I can't get the basics down. It has occurred to me that I don't really need to put the Off time into a variable. When the unit goes off, I can just subtract the On time from the current time, and that should give me the result I'm looking for. But I've also come to understand that storing the On time in a variable, means I have to recall it for the math, and it needs to appear as time data, not just a series of numbers for the calculation.
This script does put the time into the Off Variable, but it also add 6 decimal places, which, of course, I don't need. I have a similar script for the On Trigger
from datetime import time
from datetime import datetime
from datetime import timedelta
OffTime = datetime.time(datetime.now())
indigo.variable.updateValue(254766893, value=unicode(OffTime)) #puts off time in variable
I was hoping that this line would get rid of the fractions of a second, but it doesn't, at least not as scripted
OffTime = datetime.time(datetime.now(%H:%M:%S))
But aside from the decimal issue, I need to recall the data from the ON variable, have it appear as time, subtract the Off time from the On time, and then store it in a variable. I'm also going to need to make this a cumulative number, but I think I can probably figure out how to do that if I can get just the basic run time calculated. With any examples of how to do the basic time math, I can probably figure out how to do the rest of this project, but for the moment... I'm stuck.. :(
As always... THANKS in advance!
on = indigo.variables[1506159459] #acOntime
off = indigo.variables[254766893] #acOffTime
total = indigo.variables[985437501] #cummAcTotal
t1 = time delta(datetime.time)(off)-(datetime.time)(on)+(total) #this is obviously the problem line
indigo.variable.updateValue(985437501, value=datetime.time(t1))
Sat May 25, 2019 2:32 am
Re: Subtracting Time
Just as an aside, have a look at the Timed Devices plugin.
I *think* that has a device type that does exactly what you want; tracks how long a given device has been in a given state, be it AC duration, gate left open, ....
Sat May 25, 2019 4:34 am
You can plot usage with indigoplotd
Select device state and measurement: count w reset once a day
That gives you the number of minutes in a day plot.
Sat May 25, 2019 5:43 am
If you want to learn how this stuff works, here is an example of how to do time math (if I didn't screw it up). You'll need to modify it to your liking.
import datetime as dt
# variables are stored in Indigo as strings
now        = dt.datetime.now()             # this is already a datetime object
on_time    = "2019-05-25 01:23:45.123456"  # this is a string
off_time   = "2019-05-25 01:32:45.974913"  # this is a string
total_time = "0:01:23.456789"              # this is a string
on_time_d  = dt.datetime.strptime(on_time, "%Y-%m-%d %H:%M:%S.%f")   # converts the string to datetime object
off_time_d = dt.datetime.strptime(off_time, "%Y-%m-%d %H:%M:%S.%f")  # converts the string to datetime object
t       = dt.datetime.strptime(total_time, "%H:%M:%S.%f")  # converts the string to datetime object
total_d = dt.timedelta(hours=t.hour, minutes=t.minute, seconds=t.second, microseconds=t.microsecond)  # converts the datetime object to a timedelta object
diff = off_time_d - on_time_d  # Subtracting a datetime from a datetime yields a timedelta object
new_delta = total_d + diff  # Add the two timedelta objects together
indigo.server.log(unicode(total_time))  # old accum time
indigo.server.log(unicode(diff))        # latest delta
indigo.server.log(unicode(new_delta))   # new accum time
Outputs:
   Script                          0:01:23.456789
   Script                          0:09:00.851457
   Script                          0:10:24.308246
Sat May 25, 2019 7:54 am
jltnol offline
Hey Folks this has been most helpful. I think I had tried the Timed Devices years ago, but have downloaded it and will take another look. It seems like it will do what I need/want.
And Dave, as for your script, I had ran across something very similar online in my search, and can almost understand how it works... I was able to get the OnTime trigger to put the data into the OnTime variable, and the data looks exactly as the sting data in your example. Getting the OffTime trigger to do the same is done as well.
But don't understand how to get the data from the variable back into the script. Where you have
obviously, I need to get that data from the OnTime variable., and that's what I don't get. I'm 99% sure the rest of the script I can bang on and figure out.
Is this what I need to do?
on_time = indigo.variables[1506159459] #acOntime
for this one line? Again, I think I can figure out the rest.. :)
Sat May 25, 2019 9:30 am
Close:
on_time = indigo.variables[1506159459].value #acOntime
Your version gets an Indigo Variable object itself. The latter get the value of the Indigo Variable Object. So assuming your variable contains exactly the string as outlined in @Dave's post, it should work.
Sat May 25, 2019 9:53 am
jltnol offline
I'll work on this and see what happens...
As ALWAYS.
Thank you.
