Altering data series and pipe them to the next plugin
Tue Mar 05, 2019 1:47 pm
msageryd offline
Is there any way to calculate a dataseries of my own based on received z-wave data and use this series as input to another plugin? I'm sorry if this is a stupid question. I don't know how Indigo plugins works. I'm kind of hoping that they can work with data as streams which are pipeable between plugins.
More specifically, I need to calculate a difference between current and last value and divide it by the time delta and get hold of this data in Grafana. I'm using the Grafana Home Dashboard plugin.
Why do I need this?
I want to plot accurate power consumption charts (W), but:
1. The Aeotec reports accumulated energy (kWh) and momentary power (W). Unfortunately, the W readings are not averaged since last reading,
i.e they are essentially unusable for charts.
2. InfluxDB does not seem to have functions for making this calculation (surprisingly)
Data reported from Aeotec HEM
| energyAccumTimeDelta | energyAccumTotal | energyCurrLevel |
| 0.50 hours           | 1 kWh            | unusable value  |
| 1.4 hour             | 4 kWh            | unusable value  |
Instead I want to feed the following to InfluxDB via the Grafana plugin:
| energyAccumTimeDelta | energyAccumTotal | averagePower          |
| 0.50 hours           | 1 kWh            |                       |
| 1.4 hour             | 4 kWh            | (4-1) / 1.4 = 2.14 kW |
Tue Mar 05, 2019 4:48 pm
Dual offline
Re: Altering data series and pipe them to the next plugin
I want to plot accurate power consumption charts (W), but The Aeotec reports accumulated energy (kWh) and momentary power (W). Unfortunately, the W readings are not averaged since last reading,
If I am following you, a possible solution (screenshots) is shown below (consisting of 6 variables, 1 trigger with 5 actions including a python script as the 5th action):
Wed Mar 06, 2019 5:17 am
msageryd offline
Thanks a bunch!
This seems to solve the problem, but it's way too much work imo. I have three Aeotec meters, so the variables and scripts would be quite messy.
Would it be possible to implement something like this with Indogos plugin structure?
https://www.home-assistant.io/component ... tatistics/
Wed Mar 06, 2019 8:33 am
It is possible to interact with plugins in this way, and the Matplotlib plugin shows one way to do this. Using this structure:
matplotlibPlugin = indigo.server.getPlugin("com.fogbert.indigoplugin.matplotlib")
payload = {'x_values': [1, 2, 3],
           'y_values': [2, 4, 7],
           'kwargs': {'linestyle': 'dashed',
                      'color': 'b',
                      'marker': 'd',
                      'markerfacecolor': 'r'},
           'path':'/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/images/controls/static/',
           'filename': 'chart_filename1.png'
    result = matplotlibPlugin.executeAction('refreshTheChartsAPI', deviceId=0, waitUntilDone=True, props=payload)
    if result is not None:
        indigo.server.log(result['message'])
except Exception as err:
    indigo.server.log(u"Exception occurred: {0}".format(err))
you can pipe data to the plugin and have it output charts on demand.
That said, use some caution. A plugin developer may not expect you to use their plugin in that way, and future changes to the plugin's code could break your script. With respect to the example above, the plugin method is designed specifically for that purpose and I plan to maintain backward compatibility of the plugin API as much as possible.
Thu Mar 07, 2019 3:14 am
msageryd offline
Thanks Dave.
With this information at hand, I'll back down a bit from this project. I don't want to mess with things that could bite me in a year or two when a plugin stops working due to my tampering.
Instead I have increased the logging frequency so InfluxDB's last() and difference() can give me very near correct data.
Thu Mar 07, 2019 6:38 am
If you're sending data to the plugin, it's unlikely that you'll break it, and this approach wouldn't change anything within the Grafana plugin itself.
I don't use the Grafana plugin, but you could also potentially use a feature of the Matplotlib plugin to save your data to a CSV file. Save your data values to Indigo variables and use the Matplotlib Plugin CSV Engine device to store the data over time. Then perhaps you'll be able to chart that with Grafana?
A great thing about Indigo is that there's almost always more than one way to get a job done.
