Differens between two variables?
Thu Jan 03, 2019 5:29 am
Gusten offline
Hi
I am trying to build a smarter floor heating, today i have standard thermostats and i have a concreet floor. The problem is that here in sweden we can have a big diffence between temperatur.
So if we have 10 degrese C for a week suddenly we can have -5 degrease, the i take time for the concreate floor to heat up and it gets cold inside.
So the idea is to take todays lowest temp and towmorows lowest temp, and if the differ to much i will start heating the floor in advace
To make this happen i wonder if there is a easy way using Python script to take variable A minus Variable B and insert the result in Variable C
Thanx
//Martin
Thu Jan 03, 2019 6:38 am
Re: Differens between two variables?
Replace the variable ID values in this script with the appropriate IDs for your variables.
variable_a = indigo.variables[1961258112].value
variable_b = indigo.variables[389753528].value
variable_c = indigo.variables[314742858]
diff = float(variable_a) - float(variable_b)
indigo.variable.updateValue(variable_c, str(diff))  # variable values must be stored as strings
Thu Jan 03, 2019 9:16 am
Gusten offline
Perfect
Thanx
Thu Jan 03, 2019 5:01 pm
Gusten wrote:
Perfect
Thanx
You are most welcome.
Users browsing this forum: Google [Bot] and 2 guests
