Python Getter Setters for Indigo variables
Sat Nov 17, 2018 5:40 pm
Hackencrash offline
I am trying to create Python variable Getter Setters so that reading a normal Python variable, e.g. var.kitchen_television_onon variable will, will get the value of the matching Indigo variable and changing the Python variable will automatically set the Indigo variable such that they are in sync.
class Var(object):
    def __init__(self):
        import indigo
        self.kitchen_television_on = True if indigo.variables[1650530773] == 'true' else False
    @property
    def kitchen_television_on(self):
        self.kitchen_television_on = True if (indigo.variables[1650530773] == 'true') else False
        return self.kitchen_television_on
    @kitchen_television_on.setter
    def kitchen_television_on(self, value):
        indigo.variable.updateValue(1650530773, value='true' if value else 'false')
        self._my_attribute = value
var = Var()
print var.kitchen_television_on
However, running this code to do this produces the following results. Any idea what I am doing wrong?
on depth exceeded while calling a Python object
var.py, line 24, at top level
var.py, line 16, in kitchen_television_on
RuntimeError: maximum recursion depth exceeded while calling a Python object
FYI line 16 is return self.kitchen_television_on
Sat Nov 17, 2018 5:43 pm
Re: Python Getter Setters for Indigo variables
Changing answer.
You can't have the attribute you're saving be the same name as the property.
From StackOverflow: https://stackoverflow.com/questions/262 ... nd-setters
class Obj:
    """property demo"""
    @property
    def attribute(self): # implements the get - this name is *the* name
        return self._attribute
    @attribute.setter
    def attribute(self, value): # name must be the same
        self._attribute = value
    @attribute.deleter
    def attribute(self): # again, name must be the same
        del self._attribute
Sat Nov 17, 2018 5:52 pm
Untested
    import indigo
    def __init__(self):
        self._kitchen_television_on = True if indigo.variables[1650530773] == 'true' else False
    @property
        self._kitchen_television_on = True if (indigo.variables[1650530773] == 'true') else False
        return self._kitchen_television_on
         self._kitchen_television_on = value
var = Var()
Sat Nov 17, 2018 7:14 pm
Hackencrash offline
Absolutely perfect! Thank you FlyingDiver. Of course you can't have the attribute you're saving be the same name as the property - makes perfect sense when it's not 1am in the morning :?
Here is the code reposted as there were a couple of typos now corrected after getting past the main problem:
var.py
class Var(object):
    def __init__(self):
        import indigo
        self._kitchen_television_on = True if indigo.variables[1650530773].value == 'true' else False
    @property
        self._kitchen_television_on = True if (indigo.variables[1650530773].value == 'true') else False
# Tests
var = Var()
indigo.server.log(str(var.kitchen_television_on), type="var.kitchen_television_on")
var.kitchen_television_on = True
indigo.server.log(str(var.kitchen_television_on), type="Should be True")
var.kitchen_television_on = False
indigo.server.log(str(var.kitchen_television_on), type="Should be False")
