Getting Node Name from Node ID
Fri Nov 02, 2018 1:40 pm
CliveS offline
I am trying to find the code to get a device Node Name when all I have is the Node ID.
In the debug logs I can see line 1 has the Node ID and line 4 has the Node Name, but what python code can get me from ID to Name
Z-Wave Debug RCVD requestMeterLevel: 01 14 00 04 00 05 0E 32 02 21 34 00 00 0F 47 00 00 00 00 00 00 89
Z-Wave Debug . . requestMeterLevel: node 005, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 391.1 W (float: 391.100000)
Z-Wave Debug received "Living Room TV Switch" power load to 391.1 W
I can get output like
Multi Sensor
Multi Sensor Node 152: 01 0A 00 04 00 98 04 30 03 FF 0C AD
Multi Sensor Node 152: Motion is On
Multi Sensor
but would like to grab the name and insert it like this
Multi Sensor
Multi Sensor Node 152: Kitchen Neo Motion is On
Multi Sensor
Any ideas?
CliveS
Fri Nov 02, 2018 3:55 pm
Re: Getting Node Name from Node ID
Brute force:
device_names = [d.name for d in indigo.devices.iter(filter="indigo.zwave") if d.address=="NODEIDHERE"]
I made it list comprehension because some node numbers will have multiple indigo devices (i.e. multi sensors).
Fri Nov 02, 2018 5:04 pm
CliveS offline
Thanks Jay,
Almost their but I get
Node 145: 01 0A 00 04 00 91 04 30 03 FF 0C A4
Node 145: [u'Living Room Neo Lux', u'Living Room Neo Motion'] Motion is On
Node 145: 01 10 00 04 00 91 0A 71 05 00 00 00 FF 07 00 01 08 F5
Node 145: 01 0A 00 04 00 91 04 30 03 00 0C 5B
Node 145: [u'Living Room Neo Lux', u'Living Room Neo Motion'] Motion is Off
Is their a way to filter further as I know that is a motion sensor?
CliveS
Sun Nov 04, 2018 11:47 am
Not sure this is the best way but you could try:
device_names = [d.name for d in indigo.devices.iter(filter="indigo.zwave") if d.address=="NODEIDHERE"] and d.globalProps['com.perceptiveautomation.indigoplugin.zwave']['zwDevSubIndex'] == 0
That's assuming the the Neo Motion is the first device listed when you edit it i.e. the Lux is the second device. :)
Sun Nov 04, 2018 3:57 pm
CliveS offline
Thanks for the idea but I get
Node 99: 01 0A 00 04 00 63 04 30 03 FF 0C 56 -- []
Node 145: 01 0F 00 04 00 91 09 71 05 00 00 00 FF 07 08 00 E8 -- []
Node 145: 01 0A 00 04 00 91 04 30 03 FF 0C A4 -- []
Node 156: 01 09 00 04 00 9C 03 20 01 FF B3 -- []
Node 156: 01 11 00 04 00 9C 0B 71 05 00 00 00 FF 07 07 01 07 00 F0 -- []
I think I will go back to basics and try a different approach once I have the rest of the code working
CliveS
Mon Nov 05, 2018 10:46 am
Slight typo (misplaced closing bracket), it should be:
device_names = device_names = [d.name for d in indigo.devices.iter(filter="indigo.zwave") if d.address=="NODEIDHERE" and d.globalProps['com.perceptiveautomation.indigoplugin.zwave']['zwDevSubIndex'] == 0]
